Question about Whirlpool Dishwashers
I have a Model #DU960 Pwkq1 Whirpool dishwasher leaking
I have a Model #DU960 Pwkq1 Whirpool dishwasher that has developed a leak. It drips at the center of the door only when the wash or rinse cycle are running. I checked the float and made sure that the water level is not too high. The float is free and the water actually stops filling before the float rises. The door seals on each side look ok. Any ideas?
    President:
  • 1,430 Answers
It is probally leaking from the vent assembly, rinse aid or soap dispenser. You will need to remove the door panel. Do this when the dishwasher is dry. Look closely for staining where the water is running down the inside of the door. Replace the gasket. Here is a couple links that should help with this.
http://appliancehelponline.com/dishwasherdispenser.html
http://appliancehelponline.com/dishwasherfrontpanel.html
Posted on Jun 03, 2010
GE dishwasher inlet valve leaking
see this steps and fix it. God bless you
Dishwasher Not Leveled
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily.
Door Seal
This is not very common in most dishwashers. To check this look for rips and distortion of the seal. If it is ripped or distorted you will need to replace.
Dispenser Seal
This is a more common place for a leak to develop. This is easy to check, remove the front panel and carefully inspect around the seal for water dripping or stainage. If any is found replace the dispenser gasket.
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace water inlet valve.
Drain / Circulating Pump
Some dishwashers have separate drain and circulating pumps Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. Follow the tutorial on replacing the pump
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust the switch until properly aligned.
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the toe kick and maybe the front panel to inspect.
Jul 13, 2013 | GE Dishwashers
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
Dishwasher leak dripping down side of drain solenoid
it is possible that the plastic has developed a crack at the end of the threaded section
if you are handy with tools , turn the water off and remove that assembly( turn the power off at the plug)
check with a service agent spares department first as that part may not be available because of the age
Jun 13, 2017 | GE 24 in. GSD2220Z Built-in Dishwasher
EWDW6505GS0 Model Electrolux dishwasher 10 months in service has Error Code 01. Leak. What to do?
Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Feb 14, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
All the light on my new, Electrolux dishwasher are
Remove the kickplate at the bottom of your dishwasher and see what error you are getting. Likely a leak error.Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Jan 25, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
Electroluxe dishwasher starts and once water runs it quits working and all the lights on the display start blinking and it won't work. Any ideas?
LG dishwasher is dripping water from vent onto floor
Good that it is working. Recommend you keep a lose eye on the vent on the bottom of the door panel. This model will probably begin leaking again if it has not been retrofit with a kit that LG developed.
Please open a new problem when it starts to leak and please provide the Model and serial number when you do. Good Luck!
Mar 24, 2009 | LG LDF6810ST Stainless Steel Built-in...
Bosch 6802UC dishwasher is leaking water from bottom of door
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Jan 22, 2009 | Bosch 24 in. SHU6802UC / SHU6806UC...
Electrolux 6505GSO dishwasher. Says ERROR 01 onled panel and will not function. What is this code and how can I make the the thing work?
Dec 31, 2008 | Electrolux 24 in. EDW5505EPS Stainless...
Leaking dishwasher
Sorry about the delay in time in getting back to your problem if not already resolved heres what you can try. Remove the bottom panel and run through a load, to see exactly where leak is coming from, most common place for leak is through the heater hold down brass nuts. They crack and need to be replaced
Feb 27, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Dishwashers Logo
162 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
