Question about Sony PCG-GRT100 15-INCH XGA LCD (A8113853A) PC Notebook
LCD screen flickers off & on, then may stay on for 5 minutes then darken whereas you can barely see the information on the screen.
    Problem Solver:
  • 17 Answers
This is a laptop. If so sounds like your backlight/inverter is going bad. Check the following links if it is a laptop:
http://www.fonerbooks.com/test.htm
http://www.fonerbooks.com/laptop14.htm
http://www.laptoprepair101.com/laptop/2009/05/04/how-test-lcd-screen-inverter-in-laptop/
http://www.laptoprepair101.com/laptop/2007/09/05/troubleshooting-laptop-with-backlight-failure/
Posted on Jun 04, 2010
I have a Zenith Z50PT320 plasma tv. After a few minutes the picture turns very posterized and flickers. Should I replace the Main Logic CNTRL T-Con board?
There is no T'Con board to Plasma TVs. Flickering can be of many reasons. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Dec 09, 2016 | Zenith Televison & Video
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
The screen flickers and darkens while watching the TV. It is a 3 month old Bush DLED32165HD. Adjusting contrast/brightness/sharpness makes no difference. Turning off the TV and turning it on again, th
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jan 14, 2015 | Bush Televison & Video
Dotted lines across the top of the screen and flicker in other video ports.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 05, 2017 | Westinghouse LVM-42w2 Television
Gateway laptop screen darkens after boot up
Have you updated a Graphic driver? Does it Dim on battery and AC? Look at power settings. Control Panel, Power. You could Rool-Back the graphic driver to see if that changes the problem. A Gateway mt6841 has Windows XP OS, right?
Nov 27, 2012 | Gateway MT6841 15.4 WXGA SHINY LCD SCREEN
After 5 minutes monitor screen dims--can faintly see the windows screen and then it flickers out and there is nothing. Any ideas?
the monitor may be going into power save mode which it should come out of when you press a key or move the mouse but it sounds like you have tube inverter issues. Your screen has light tubes behind it to illuminate the screen, if the tubes or the inverter develop a fault, then a very dark screen can result as the tubes are turned off. There may also be an ambient light sensor which will darken the screen in low ambient light. If the sensor is faulty, darkened screens will result. If the inverter is failing, you may be able to replace it, contact viewsonic. if the tubes are failing, replace the panel or the entire monitor. If the ambient light sensor is faulty, replace the panel or entire monitor as the sensor is part of the display panel.
Nov 02, 2009 | ViewSonic VG900b 19" LCD Monitor
Display flickers and darkens
There are two main possibilities.
1) The cable between the inverter and backlight burn on the screen is loose. You will need to open screen to reseat it.
The other is that the inverter or backlight is dying and your display will stay dark sooner or later.
If you find this helpful please rate so.
Thanks
May 06, 2009 | Computers & Internet
Computers & Internet Logo
87 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
