Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer with Curved Shaft #P1500
The trimmer starts like a dream but only runs with choke on
The trimmer starts like a dream but only runs with the choke on and no throttle. After a while (10 mins) it stops altogether and won't start again. If I rev it up after starting it will get the rpms, but then dies. Idling with the choke on will work, but the rpms are too slow for any meaningful weed eating to get done. The chain saw attachment is worthless because of this lack of power.
  • 416 Answers
Sounds like the carb needs to be removed and cleaned. It the chunk of metal that has the fuel line going to it on top of the engine.
Use a phillip screwdriver and possible a small ratchet to break it down and clean it thuroghly with gasoline.
After you get it back together and have cleaned it up as much as possible, crack her up with full choke again. this time though, allow it to run and barely ramp up the rpms enough to give it a little lug. When the engine seems to begin losing power, (these adjustments should be as small as possible until you get her running smooth) dial the choke back just enough to ramp up the rpms. This will probably take a few tries, but most definately should work in your case.
Once the trimmer is running smooth with the choke off you will be good to go.
Many times our trimmers and other 2cycle engines dont get the proper attention to keep them running up to par. Take the time to consider the unique properties of your tools to determine any possible future repair. Anytime you have and engine that burns a home mixed fuel there will be the risk of trash in the fuel system
GOOD LUCK AND PLS RATE THIS POST!!!! :D
Posted on Jun 03, 2010
  • 32 Answers
In North Carolina because of the Ethanol in the gas, I have problems. To get my machines to run efficiently I have to use the best grade or find a Gas Station like Valero that don't use ethbanol.
Posted on May 29, 2012
Manual for a craftsman weedwacker model 31679108
Trimmer Starts but stall out as soon as throttle is used and choke turns off. if I hold the throttle and pull the choke it runs but will stall as soon as choke is let go.
Jan 31, 2011 | Craftsman 27cc 2 Cycle Crank Straight...
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Stalling out
Generally with two cycle engine as soon as the engine starts the choke needs to be moved to the off or open position. Some chokes have a middle position that lets the motor run until it is warm enough to move the choke into the open position. In other words weather it is a two or four cycle engine the choke is used only to start the engine. If you unit is newer and still does not run well with the choke in the open position, you may need to adjust the hi-speed circuit to a richer one.
Jul 13, 2009 | Troy Bilt Tb70ss Gas Trimmer
Ryobi 720r trimmer starts ok but stalls when the
The carburator needs to be adjusted a little, thin our your mixture screw when the trimmer is warmed up and idling. Well how do you get it to idle? I usually have to play with the choke lever with the throttle wide open going from choke to partial choke as needed to keep it running. Adjusting can be tricky, you need a small screwdriver. Screw all the way in then back out 3 to 3.5 turns. this should get you close. Adjust idle as needed.
Jul 05, 2009 | Garden
Homelite gas trimmer will not run without half choke and throttle
You need to disassemble the carb. and spray with carb. cleaner. If you need tips on how to do this, just let me know. You may need a new carb. kit as well, but we won't know that until you first perform the first step, or if the carb. parts are more than 3 years old. If they are, then go ahead and buy the carb. kit and replace the parts.
Jim
Jun 01, 2009 | Homelite Mighty Lite Lawn Trimmer
It acts like it is flooded, starts with choke off and throttle depressed. runs until carb runs out of gas then dies
Yes, Your carburetor sounds like it needs cleaned. Or you may possibly need to purchase a carb. kit for your trimmer if the cleaning doesn't do any good. When cleaning the carb. use a Den Tek Brush, (teeth cleaning brush), to clean the small ports. Also, check the small screen in carb. Can get clogged easily.
Jim
May 28, 2009 | Garden
Stops when given full throttle
Most likely carburetor needs adjustment.
May 15, 2009 | Garden
Poulan 25cc 2-Cycle Gas Powered String Trimmer with Curved Shaft #P1500 Logo
544 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
