Question about Goodman CLQ36AR49 Air Conditioner
Air Conditioner shut down.
I year old unit. Had Heating unit replaced this year too. when heating unit was installed, they busted the air compressor. Worked for 2 months, now on 90 degree day the unit just shut down. Installer, (Team Electric says they can't tell me when they can come.) Any advice
  • 416 Answers
Set your thermostat to "ON". If the system continues to shut off and resumes later then you have an electrical failure within the unit or its just cluttered with junk. Check through the vent holes visually for debri. If there is enough to cause concern, remove the nuts holding the grill above the fan once you have flipped the breaker for the unit. (you definately dont want that thing kicking on with your arm inside)
if the unit stays on then you have a bad thermostat.
also pay attention to the temp of the exterior unit, if it gets too hot to touch then that is a sign of an electrical component failure and needs to be diagnosed through more troubleshooting
GOOD LUCK AND PLS RATE THIS POST!!!!!
Posted on Jun 03, 2010
I have a Crosley 220 volt 18,500 btu window unit air conditioner with a heat pump. The cool air works fine when set on cold, but when set on heat, it doesn't blow warm air. What should I check first?
18000 BTU Air Conditioner ' The Air Conditioner Guide
www.theairconditionerguide.com > BTUs
An 18000 BTU air conditioner is your best bet if you are looking to cool a room ... 2) Frigidaire 18,500 BTU Window-Mounted Median Air Conditioner with ...Troubleshooting Guide. Lost your Everstar air conditioner manual? Fix it tips are here!
Nov 26, 2015 | Crosley CAHE18ER Air Conditioner
I have a Goodman GPH1324H21A the fan comes on and the AC kicks on for a couple of minutes then shuts down what's wrong with it?
if it's 4 years old it doesn't have r22. Are BOTH fans running when ac shuts down? Inside unit or outside unit shuts down?
Jan 08, 2018 | Goodman GPH1324H21A WallWindow Air...
Unit won't cool. Unit is set on is on cool, but warm air comes out. Is there a reset button on the unit ? Unit is 21 1/2 years old.
Some of those old Mach 3's have a manual reset pressure switch, but you will have to take the cover off to find it. Most manual resets have a red button to push to reset. The unit may be low on refrigerant or the condenser coil stopped up with dirt.
May 13, 2011 | Coleman Mach III Air Conditioner
The unit has stopped heating,it is around 4 years old
does it cool when on cooling mode? . if so and heating is the only problem . then its a stuck reversing valve either solenoid or stuck vavle
Nov 08, 2010 | LG Heat cool Window Air Conditioner
There is water coming out of my indoor unit. So much water that I had to shut off the ac unit. It is a Mitsubishi Mr Slim split type air conditioner/heating unit
water coming out of an a/c is normal .its water outlet hose is wrongly installed or not installed at all.get it installed.also level the indoor unit towards the water outlet side when u install the hose .
Aug 10, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Hunter thermastat, model 44860 not working
Is the compressor running? is the outside unit clean and free from debris? does this unit work in the heating mode during the winter, and is it still capable of that now.
Jun 01, 2009 | Ruud UAMB Air Conditioner
Hot air coming out of ac
The workings of split units can be difficult to repair. I would have a professional repairman look at it.
May 08, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Goodman CLQ36AR49 Air Conditioner Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
