Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
Starter coard broken
Poulan chain starter system I require information
    Problem Solver:
  • 14 Answers
The starter housing is removed with a #20 Torx bit, then the cord replacement becomes obvious. You'll need to prewind the spring about half it's capacity before engaging the cord reel to the rewind spring. Good luck with it. These cords won't break if you use short pulls, preferably with your foot holding the right hand hold to the floor.
Posted on Jun 07, 2010
How much compression should the saw have?
What Causes Too Much Compression on Poulan Chain ...
homeguides.sfgate.com > ... > Other Types of Mortgages
Many makes of gasoline-powered yard tools, including Poulan chain saws, use two-cycle, or two-stroke, combustion engines. ... Pull the rope out and oil it to see if that helps the problem. ... How Much Compression Should a Stihl 066 Have? ... Pull Starter on a Poulan Chain Saw · Oil Pump Removal on a Poulan Chain Saw ...
The Timber Trades Journal and Saw-mill Advertiser
Nov 26, 2015 | GCSP Husqvarna 340 345 346 350 353...
Starter pull cord won't pull out
Some times fuel and /or bar oil will leak into the cylinder and cause this. Pull out the spark plug and pull the starter coard a few times to push it out.
Jun 09, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Need to have a manual on this wild thing so that i know the right ratios for the gas.
This Chain Saw requires a 40:1 gasoline to oil mixture. This is typical for all 2-cycle motors. More information can be found here:
http://www.ehow.com/how_4464807_fuel-poulan-wild-thing-chain.html
Aug 30, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
One broken bolt that holds the chain bar. It
You do not tell us which model Poulan, that limits how much help we can provide. The head is probably in the oil tank.
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/showthread.php?t=63219&highlight=Bar+stud+replacement
Post 6 in this thread is quite good. I have seen a post that required repair of the casting (with photos) to repair. I was not able to find it.
Look closely at the old one, once removed, See if it has some sealer applied
The IPL for your saw can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If I can be of further help please reply below. HTH
Lou
Feb 08, 2010 | Poulan Garden
I have apoulan pro 10 chain saw need to find arepair shop in my area to fix the brake which is completely broken
The saw or your manual should have an 800 number to call to locate a dealer. Or do a google search for poulan repair and you should get enough information to find a dealer.
Sep 13, 2009 | Poulan Garden
PULL ROPE WON'T RECOIL AND IS FULLY OUT
Possible broken return spring or excess junk in starter mechanism. Remove starter assembly to check out.
Jun 27, 2009 | Poulan Pro Chain Saw 46cc 20"
I have a poulan 305 pro chain saw were do the 2 fuel lines go?
Find your model nuber here:
Poulan.com
The drawing containing your fuel system is as good as it gets. If you need more help contact PoulanPro.com. HTH
Lou
Jun 03, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan 16" cannot start...pull cord locked up
Remove the cover, should be 4 screws that holds it on once the 4 screws are loosened the rope could rewind on its own. If not check to make sure the spring is not broken.
Apr 06, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
The cord to my Poulin chainsaw is sticking
To traxtor06
Your problem sounds like a broken starter spring. If the spring is broken it will slip allowing the tension to be released and not fully retract the rope.
Mar 27, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Broken recoil spring
A new spring comes wound tight enough to be dropped into place in the starter housing (Easiest).
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so i tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool.
Both methods require about 2 turns of pretension to rewind the cord when pulled.
Lou
Mar 21, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
123 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
