Question about Maytag MER6772 Gemini Electric Kitchen Range
The oven shuts itself off after preheating.
The oven is only two years old. The upper oven shuts itself off after preheating.The bottom oven works just fine.
  • Maytag Master
  • 43,501 Answers
If your electricThe oven shuts itself off after preheating. - 2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Jun 07, 2010
MY Jenn Air model WW2780W isn't coming on. When I click on the control panel it clicks then the display says 140 preheat on.. for about 30 seconds then it shuts off it has done it for awhile and it would...
I have the same double wall oven, and it will "turn on" and then shut off after about 30 seconds. The top oven stopped working 4 years, the bottom oven stopped working about 2 years ago. Both are doing the same thing. I'm interested in replacing the capacitors to see if that fixes the issue. There are 2 larger capacitors (1000uf 35v), and lots of smaller ones. Is it safe to assume it's the larger ones that need to be replaced? The only other 2 matching capacitors are very small (0.47uf 5v). I know this is an old thread but would appreciate any advice. Thanks!
Sep 27, 2013 | Jenn-Air Ovens
Top oven doesn't heat properly
What is the model number of the unit?
Dec 03, 2012 | Ovens
It takes my electric over a long time I think to
That is a long time, but please give more information on what type of oven you have, and how old it is if the following does not solve your problem. First, Make sure you have not covered the bottom of the oven with any type of barrier to keep the oven clean (aluminum foil or inserts), it blocks the vents. If it is an older convection oven, preheat on bake and set the convection after it has preheated. Check the elements. Lift up the bottom panel and do a visual check of the element. Take out the bottom panel and turn the on oven on somewhere near 450-500 degrees. Visually inspect the element and see if there are bright red areas and dull areas. If the element has red hot areas and dark areas, you need a new element. If the element does not get red at all, you need a new element. Electric ovens usually have an upper and lower element, so you should check both before replacing one. The broiler element should be visible without removing anything, just look at the top of the oven after you set to broil. Lastly, make sure the oven door shuts snugly and that any gasket around the door is in good condition. If you don't know if the door is tight enough, just lean up against it to see if it preheats more quickly. The oven also has a temperature sensor, but from your description, that would not be the case because you did not mention trouble maintaining the temperature.The good news is that elements are usually cheap and easy to replace. Try to find your owners manual, it will tell you what part you need. If not, write down as much info on your oven that you can and take the element with you to the parts store. If this is not helpful, leave comments with more information and I will attempt to solve your problem. thank you for your question.
Nov 18, 2009 | Computers & Internet
Tappan gas range TGF364 not heating properly
try changing oven senso located in the oven cavity (upper right or left). its approximately 4-6" long and has a plug-in on the back of the oven
Mar 11, 2009 | Tappan TGF364AS Gas Kitchen Range
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Whirlpool gs475lems range oven problems
my oven was converted to LP gas we move overseas.It worked for about a year then all of a sudden the oven stopped working. The burners work perfectly but the oven just keeps clicking after preheat is finished. We replaced the upper electronics board so what could it be now
Dec 02, 2007 | Whirlpool GS475LEKS Gas Kitchen Range
Maytag MER6772 Gemini Electric Kitchen Range Logo
1,555 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
