Question about Dell Inspiron B130 Notebook
Dell inspiron b130 won't boot up.
My laptop comes on with dell logo screen then goes blank in 10-15 seconds. Three of the green indicator lights are on, then everything shuts off in less than 10 minutes.
  • dirt dauber Apr 10, 2008
    I replaced the LCD, and that made it stay on.
  • 472 Answers
Connect an external monitor to the laptop and see if you can see what is happening on that.
It is a possibility that your inverter is faulty and will need to be replaced. They will normally power on for a few seconds, then cut out.
Remember to set the laptop to use the external monitor with the function keys.
Posted on Apr 09, 2008
  • Peter Thompson
    Peter Thompson Apr 10, 2008
    Nice work =)
    Sounds like either the inverter was indeed bad or the CCFL (light tube inside the actual panel) was broken.
    Good to see you have it living again.
Dell Inspiron mini 10. The system will not boot up, after the Dell logo screen and blue bar goes away, the screen is blank and the curser is flashing in the upper left corner of the screen. F11 isn't...
That cursor indicated that the BIOS can't find an Windows installed on the hdd. Since even the recovery partition appears to be inaccessible the only thing left is to reinstall it using the recovery cd that should have come with it when you bought it If you don't have it you can order it from Dell.
Sep 01, 2011 | Dell Inspiron Mini 1012 Netbook...
My Dell Inspiron B130 won't turn on. The battery light blinks yellow twice then green, but that is the only thing happening.
Take the battery off completely and drain the flea power from the laptop by holding down the power button while the battery is off. Hold down the power button for about 15-20 seconds to ensure no power remains on the laptop. Check if your battery has a drain button too. Drain the battery and place it back on the laptop.
Charge it for about 30 minutes before you turn it on. See if it works.
Post here if you need further help.
Jul 30, 2011 | Dell Inspiron™ B130 PC Notebook
The pc starts and the Dell logo comes up but no windows boot
press the Fn Key and the power button see if the diags will run. You may have a hard drive problem or an issue with the operating system
Jul 09, 2010 | Dell Inspiron 1545 Notebook
My Dell Inspiron B130 will not turn on
The battery is critically low, indicating that it is not getting a charge from the AC adapter. If the system will not power on from the AC adapter, then the motherboard power connection is suspect.
Motherboards are about $100 on EBay
Feb 01, 2010 | Dell Inspiron B130 Notebook
Dell B130 boots but nothing on screen and no boot up sounds
If you are seeing an shadow image on the LCD and you have video on an external monitor, then the LCD backlight has failed. The LCD will need to be replaced
I googled B130 LCD's and they generally run $125 to $200
Jan 13, 2009 | Dell Inspiron B130 Notebook
Inspiron B130 won't boot
plz try to boot through safe mode, if you can then log in normally.
if you cant boot from safe mode then you have to reload or repair your os.
Dec 23, 2008 | Dell Inspiron B130 Notebook
BOOTING PROBLEM DIAG PROBLEM
What os you running? it booting problem or diag problem? If you can access windows desktop, you can try use Microsoft Bootvis to Diag your boot problem and Bootvis also can optimze you boot time :)
Sep 26, 2008 | Dell Inspiron B130 Notebook
B130 Monitor Problem
Connect an external monitor at the back of your laptop and see if the display is fine. If the display is fine with the external monitor, it means to say that there's something wrong with your LCD's backlight. You may have to contact Dell Technical Support to check if your system is still under warranty.
Thanks! :)
Aug 26, 2008 | Dell Inspiron B130 Notebook
Dell Inspiron B130 wont boot
First remove the battery from the PC! Leave it off for a short period of time! about 2min. This allows the computer to erase anything in temporary memory. Place the battery back onto th PC and try to boot it up. The other thing you can do is boot the pc up with just the power cord in place. See if it boots just from the power cord. Sometime the batteries from dell causes the whole entire PC to become unresponsive.
Nov 26, 2007 | Dell Inspiron B130 Notebook
Will not go past startup screen
I think u need to updrage ur bios and RE-INSTALL UR WINDOWS
Oct 26, 2007 | Dell Inspiron B130 Notebook
Dell Inspiron B130 Notebook Logo
262 people viewed this question
Alun Cox
