Question about GE Refrigerators
GE Profile Side by side model number TFH22PR. Works great, but ice maker not working. It produces water from door just fine, but no ice. What's up with that? Clogged somewhere?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve. If still the issue is not resolved then remove the ice bin, Remove the wires from the auger motor. With the freezer door open and the door switch depressed, push the ice cube release and check for 120VAC between the motor wires. If there is 120VAC then the motor has gone bad. If there is no 120VAC then the control board (module time delay) has to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 03, 2010
Testimonial: "If water is getting to the door wouldn't the water flow have to be good? Seems like testing the water flow would be a waste of time"
  • Rylee Smith
    Rylee Smith Jun 03, 2010
    You are right water is getting to the door however, it is not making ice so it could be the water inlet valve as this refrigerator uses a dual inlet valve which can go bad and cause this. Also as I said, If still the issue is not resolved then remove the ice bin, Remove the wires from the auger motor. With the freezer door open and the door switch depressed, push the ice cube release and check for 120VAC between the motor wires. If there is 120VAC then the motor has gone bad. If there is no 120VAC then the control board (module time delay) has to be replaced.
GE Ice maker works makes ice! continues to eject ice when glass is pulled away
the button behind the pad is stuck,bad model number,if it's a side by side open the fridge door.look up on top and on right wall and you'll see a tag with model and serial number
Oct 12, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a GE Profile refigerator ( model # PSCS3VGXAFSS ). I have had it for a year. It is still under warrenty. The question that I have is that the ice maker just stoped making ice. It goes through all of...
There is a dual solenoid water valve. One solenoid controls the water dispensor the other is for the ice maker. If its under warranty you should definitely have it looked at.
Sep 20, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ice maker not working Water works fine in the door. (GE Profile side by side)
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
gfs4
May 29, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE Profile refrigerator side by side, water and ice through door. Ice maker works fine, water will not shut off. Had to turn water to frig off.
The water inlet valve on the back where the water supply connects to the unit is stuck open. You may can clean the valve out and get it to closing or just replace it.
Dec 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
I have a GE Profile side by side fridge and need help with my icemaker. It's making great ice but seems to have to much water. Is there some way to adjust the time on for the water fill valve?
Your model has the electronic control behind the front cover and not very serviceable. The part number providing your refrigerator is the PSW26P model the ice maker part number would be WR30X10093 for that Model. You may also take into consideration that it is also a possible bad water valve on the rear leaking after shut off. That would show up as water running over the sides and the freezing and possibly freezing the fill tube in the back of the ice maker causing water to go everywhere. But most likely it is the control board inside the front of your ice maker. Thanks Sea Breeze
Oct 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Refriderator model GSL25KGRB RB water dispenser no water.
Water line may be frozen right where it enters the ice maker. Or the water valve may not be working.
Aug 26, 2009 | General Electric GE Profile CounterTop...
GE Profile TFT25 PR. Ice maker quit producing
Had the same problem. Replace the water filter and is should begin making ice again.
Mar 05, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
847 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
