Question about Minolta EP4000/5000 CS/PRO Copier
Minolta EP4000/5000 CS/PRO Copier how do i change my toner
  • 1,110 Answers
Open the large front door. The toner bottle is at the upper left side. Swing it out by pulling out on the left side. Slide the old toner bottle out of the gray holder. Now take the new cartridge, keeping the hole with the seal on it on top. Slide it into the holder where the old one was. There are 2 "pegs" on the bottle that will clip into a clip on either side. Once fully installed simply pull the plactic tape towards you to remove it from the bottle and swing the new toner back into place and close the front door. Thats it!
On most of the 4000/5000 models the toner instructions are on a label inside the front door.
Good Luck and Thank You for using Fixya.
Posted on Jun 03, 2010
What's your problem?Minolta EP3050 CSPRO Copier printed copies, then display read ''malfunction detected'' code C0070
Main hopper toner replenishing motor M8 failure to turn.The output from toner bottle home position sensor does not go high within 5 seconds after M8 motor has been energized.Verify the conectors,sensor and motor.Open the front door,turn the toner bottle 1/4 turn clockwise manually with the bottle holder closed.Under the above condition does the toner bottle turn when the front door inter lock switch is turned on?NO - change the toner replenishing M8 motor.Does the toner bottle stop at home position after turning?NO- change PC35 toner bottle home position sensor.Recomanded use vacuum cleaner.
Aug 14, 2012 | Konica Minolta Copier Toner EP6001 CS Pro...
Dear sir my minolta problem the minolta is stoping after copier one paper please i needed the of 1083 including the problems and soulving for this copier
IS there toner in the machine or is it low if low you need to add toner if there is toner try doing an f8 adjustment
Jan 23, 2011 | Minolta EP1083 CS/PRO Copier
EP1052 cs/pro copier hang but the light color is still green , I switch off the power and on it again , but nothing is change !!! can you tell me in instruction what to do please ... thank you
Minolta EP1052 - Operates but nothing prints on the paper. Toner seems OK. Can't get to print in any of the exposures.
Any ideas - or has it finally died??
Nov 30, 2010 | Minolta EP1031/1031F CS/PRO Copier
Minolta CSPro copier is not printing
Change the transfer/separator corona holders,corona wires and clean the optics(mirrors,lens exposure lamp),and make a copies.
May 24, 2010 | Minolta EP4000/5000 CS/PRO Copier
I have a Minolta cs pro 2080 copier, shading on copies
3 possible causes:
1) The optics are dirty thus making your copy darker. The test for this is to manually lighten the copy using the exposure control on the panel of your copier. Lighten the copy several positions and see if the copy gets better. If it does then the optics need to be cleaned.
2) The copier is overtoned. This means that the toner to developer concentration is to high. This will require a trained technician to lower the toner ratio and then recalibrate the toner/developer ration using the F8 mode.
3) If the shading gets much worse as you run say 10 copies in a row then the drum cleaning blade would be the cause. So run 10 copies of something and compare the first copy out with the tenth copy out. Do you see a dramatic difference in the amount of background or "shading"?
Good Luck and thank you for using Fixya.
Mar 16, 2010 | Minolta EP4000/5000 CS/PRO Copier
Malfunction code C00 71
These codes are generally related to the toner motor, if you have changed the toner lately.Check the install of the toner cartridge, remove it and reinstall it, close up the machine and try again.
Hope this is of som help.
Ed
Apr 26, 2009 | Minolta Office Equipment & Supplies
Smudge on the paper
When you say smudges, do you mean toner spot or blobs of toner on you pages? If you get random blobs of toner... You need to take out the drum unit & remove the primary charge unit & remove the drum & vac. out a small little grove that seats right below the developer mag roller... It is most likely filled with toner and is dropping on to you paper as copies are being made. Good Luck
Feb 18, 2009 | Minolta EP4000/5000 CS/PRO Copier
Service
it means it time for the cleaning web, and waste toner bottle to be replaced. once you replace it you can reset the indicator.
thanx,
mikey
Mar 19, 2008 | Minolta EP4000/5000 CS/PRO Copier
Ep2080 minolta cspro
Ep2080 minolta cspro error code comes up with c0500
Dec 06, 2007 | Minolta EP4000/5000 CS/PRO Copier
129 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
