Question about Ruud UBHC Air Conditioner
My dog chewed through a group of multi-colored wires on my AC outside. Is there any way that i can fix this?
I have same problem puppy chewed red green white from house to ac. I only have black and yellow open on outdoor ac unit. which wires to which or does it matter? not sure where green goes or if it is just loose. Help mah
Posted on Jul 16, 2010
    New Friend:
  • 9 Answers
HI there well i think what you dog chewed on was the thermostat wires. if you tell me the colors maybe i can help you out.
ordonez305@aol.com
This is my e-mail
Posted on Jun 03, 2010
Furnice air blows, but my ac unit outside want cut on
if the inside unit is running but the outside unit isn't - I would check the fuses or breaker. I suspect you have a blown fuse or a tripped breaker.
What is also possible is that the 'low voltage' thermostat wire (coming from the thermostat inside the house) has been cut - possibly by a lawn mower or weed eater - or chewed into by a dog.
If this is the case - you easily splice (with all power off) the wires back together using the color of the individual wires.
Jun 06, 2011 | Heating & Cooling
Dogs chewed up wiring from house to outside ac don't know what goes where
Wires used in AC for power are of different color like red for (+) black for (-) and green for (N). You can slice the rubber (about half inch) ends of broken wires and then reattach them matching the color, like red to red, black to black and so on. After that apply insulation tape on the joints. Make sure you switch off the power before you do all this work. If you are unsure, please call the AC service center and they will send an electrician to fix this.
May 13, 2011 | Heating & Cooling
My dog chewed my wires,how or where can i fix it?
Well depending on where the dog chewed the wires. If you have 2 or however many internal wires, as well as a decent length of wire If you have 3 - 6 inches that you can work with I would suggest the following. Take and individualize the colors of wire on both ends. Strip about an inch and a half long peice of wire with either a wire stripper or carefully with a needle nose plyers. After that match the color wire on the other half and twist them together. Once you have the colors all matched use electrical tape and seperate each color with a layer or two of tape. Then tape it all together. Hope this helps you out. happy gaming
Feb 14, 2011 | Logitech Rally Vibration Feedback Wheel...
The dog chewed the wiring to the condesor outside. i re wired and now the furnace turns on but not the a/c unit ouside?
Hi, well you have 1/2 of it right. Recheck the wiring and wire it color to color as you are not getting 24 volts to the condenser. If you have a gas furnace and not a heat pump you will only need 2- wires to run the outdoor unit, red and yellow. Make sure the dog didn't chew through another section also.
Shastalaker7
Jun 29, 2010 | Goodman CKL24AR24 Air Conditioner
Can't get my programable thermostat
when the dog chewed on the wires were there any bare spots where the wires could touch one another, if so the transformer is is probably bad or if there's a fuse in the 24 volt line then it is bad.
Apr 24, 2009 | Heating & Cooling
No spark
If the dog chewed up the coil wire you will need a new coil. How did the dog GET to the wiring? Did you let the dog live? The wires are color coded. Splice the wires color to color. Depending on how badly the dog tore up the wires, you may want to get a new, (or used) wiring harness and re-wire the bike following the pattern of the existing wiring.
Please rate this solution as "FixYa" if it has answered your question.
Mar 25, 2009 | 2004 Kanuni Tigrina 100
Dog chewed sensor wire so garage door won't, i
Basically any bell wire will work, available at any home centers everywhere. if the existing wire is long enough, just wire nut it together (white to white, color to color)
Feb 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
My dog chewed up wiring on outside unit and i dont know where they hook up it is a 4 wire set up with red white blue and green large ac unit dog chewed thru little brown wire leading to house and now ac...
That wire is to your thermostat which of course turns the A/C on/off. One thing you can do is to splice the wire back together w/ small wire nuts (available at hardware store or wal-mart, and just hook it up color to color and then tape w/ electrical tape. Make sure you turn your breaker off and turn off the thermostat control.
Feb 11, 2009 | Heating & Cooling
Ruud UBHC Air Conditioner Logo
235 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
