Question about Whirlpool ED2FHEXN Side by Side Refrigerator
An ice cube gets stuck in the icemaker as it empties.
The cube has to be broken free of the "fingers" that dump them into the ice bin; otherwise, it will not make any more ice until then. Happens frequently.
  • 420 Answers
The ice making unit needs to be cleaned with a mild acid such as citric acide like commercially available Ice Machine Cleaner. minerals have built up and make the ice stick to where they will not harvest properly.
Posted on Jun 04, 2010
My ice maker tube is leaking somewhere the drip pan keeps filling up and running over I have looked and I don't see any obvious dripping but I constantly have a floor full of water, unless I keep the water turned off at the valve in the basement. How do I find the leak.
Posted on Jul 13, 2010
Ice maker leaves 2 to three cubes on most dumps. then it stops dumping until they are removed
Check the the part called the cube rake. Its usually a white plastic piece with fingers that point to each cube mold. Its suppose to push the cubes out during the cube dump cycle. It sounds like a few of the fingers may be broken and not turning properly on the shaft to extract the cubes out of the icemaker. The rake should push the cubes out during the cycle.
May 15, 2015 | Refrigerators
Melting/refreezing ice in the ice makes
If the ice is the only item that appears to be melting or defrosting. I would believe the most possible issue. The icemaker is leaking intermittantly into the bin and freezing the cubes inplace.
Ric
Mar 09, 2010 | Amana ABB2527DES Stainless Steel Bottom...
GE side by side CAN17 ice maker...white ''finger assembly'' that pivots has broken two fingers, and the ice cubes are stuck in the cube dispenser. Any ideas why this happens, and how to fix it without...
You will need to replace the icemaker. The sensor that activates the heat coil in the icemaker is bad. The heat sensor allows the cubes to be released from being frozen to the ice tray. Check ebay for a new icemaker. About one third the price of manufacturer for new factory unit.
Oct 27, 2009 | GE Refrigerators
Ice maker stopped working
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Sep 05, 2009 | KitchenAid KSRP25FNSS Side by Side...
I poured water into the icemaker and ice cubes are formed but will not be dumped into the empty tray of my ge profile
The icemaker is bad then . It will have to be replaced by removing 2 screws and a plug connector . Easily replaced . Make sure the icemaker is turned on though .
Aug 16, 2009 | Refrigerators
I've got the LFX25960ST model. The icemaker
its the ice maker .water or condensation has built up in the ice maker modual and refroze upon turning unit back on.either get a new ice maker or uninstall the ice maker and let it dry for a few days and reinstall.but it could happen again that way.or maybe not.
Jul 24, 2009 | LG LFX25960 Bottom Freezer French Door...
Mod. GS6NBEXRS01 not dumping ice. there is ice in the ice-maker. the dispenser for the water working ok.
take the bin out and check for a jammed ice cube in the ice cube making mechanism. Many times they have a rotating finger that gets stuck on a cube that does not drop entirely. Hope this helps
Jul 13, 2009 | Kenmore 74252 / 74254 / 74259 Top Freezer...
Ice maker
This means that the tray is not getting cold enough to freeze the cubes. It must be no more than 12 degrees F for the icemaker to cycle properly.
Make sure your freezer is cold enough. If it is, then the other possibility is that the heater element in the icemaker (which thaws the cubes JUST ENOUGH for them to be pushed out when ready) could be stuck on. This can be easily tested, but the process is a little beyond the scope of this reply. Check this link http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Jul 16, 2008 | Samsung RS2556 Side by Side Refrigerator
Ice maker
There is something called a crusher control rod located on your icemaker bin. If you pull the bin out, you'll see it protruding from the backside of the bin. That rod inserts into the solenoid, which looks like a hole usually when looking in the freezer with the ice bin removed, it's toward the left side behind the bin.
This solenoid and rod work together to give you either crushed or cubed ice. See if the solenoid is stuck or iced up. You should be able to remove the ice and push it up and down to break it free.
Mar 26, 2008 | Maytag MSD2454G Side by Side Refrigerator
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
177 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
