Question about Homelite Consumer Products Backpack Blower/Vac, Carb
My primer bulb cracked, can I replace it? - Homelite Consumer Products Backpack Blower/Vac, Carb
  • 420 Answers
Yes, in fact event he DIY centers have parts like that available off the shelf or ACE Hardware. You will need the specific model number to ensure you get the right part or bring the old part with you.
Posted on Jun 04, 2010
Why is Ryobi trimmer primer bulb not drawing fuel?
Check the bulb to see if it is cracked, allowing air to get inside. If the bulb has lost its flexibility you might need to purchase and install a replacement bulb. It is a simple operation.
Sep 20, 2014 | Ryobi Garden
How to replace primer bulb
Unscrew or unbolt flange/fixture that hold bulb in place,,replace with new one,,,best to order by part number,,there are several sizes
Aug 13, 2014 | Toro Garden
How to change/ Replace Poulan 2150 chainsaw primer bulb
I have attached a video on chainsaw primer bulb replacement from YouTube. There are many great videos about chainsaws on YouTube.
I hope this helps.
http://www.youtube.com/watch?v=sNj2oO9L9ic
Jul 01, 2014 | Poulan 2150 Chainsaws
Primer bulb cracked on Zama C1u-W49 carb and I find no replacement
They actually dont make replacement kits or primer bulbs for that carburetor for some odd reason. Atleast I havent ever been able to find any. I work at a lawn mower parts shop and the only thing you can do is buy another carburetor. The part # for that one is 577135901. I actually sell this carburetor for $37.
Sep 07, 2012 | Weedeater Garden
No fuel in primer bulb on my echo PB 2100 blower
The primer bulb pulls fuel from the carb into the bulb and dumps back to the tank, so either the tubes are not connected too the correct conections on the carb, or there is bno fuel getting to the carb from the tank ( fuel filter ) or if the primer is on the carb itself there in a red one way valve under the bulb which maybe faulty.
Jun 16, 2012 | Echo Pb-2100 Pb 2100 Leaf Blower Inner Fan...
Fuel leaks bulb not priming.
If you have a leak the bulb will not prime. Over time the either the rubber on the primer bulb gets a pin hole in it requiring bulb replacement or one of the fuel lines cracks and introduces air into the lines. Unless the system is completely sealed the primer bulb will not work. Make sure all of the connections on the fuel lines are tight and correct the system leaks.
Thanks for choosing FixYa.
Kelly
Aug 27, 2010 | Ryobi Snap In Primer Bulb Pump 683974 ...
Pressing and reloeasing the primer bulb does not bring any feul to the fuel line. I have checked connections and they are secure.
The primer bulb may be the problem. They will get soft and loose their suction ability. Also the fuel lines can crack and cause this. If you replace the primer bulb be sure to make a sketch where the fuel line go.
Apr 27, 2010 | Garden
Primer Bulb cracked Need new one?
remove carburetter air filter cover,two 'torx' screws on top.primer bulb is retained in case by 2 plastic 'ears' push ear[s] in& bulb slides out of case.make note/label 2 fuel lines attached; one 'stem' on primer is longer than the other.replacements can be found @ lawnmower/small engine repair shops.
Oct 10, 2009 | Garden
Gas primer bubble cracked. How to find replacement
The part your looking for is called a "primer bulb" and is relatively inexpensive (under $3).
The exact bulb you need depends on the model chainsaw you have. Lacking a model number, I've provided a link to a site where you can verify which model McCulloch chainsaw you have and thus, which primer bulb you need to replace your cracked on with.
http://www.mymowerparts.com/partdetail/1125/15474.php
Once on the page, you can enter "primer bulb" in the quick search box and it will show all bulbs for all the chainsaw models available. About the 3rd section down will have the McCulloch bulbs listed.
Hope you find this Very Helpful and best regards!
Aug 15, 2009 | McCulloch Garden
Homelite Consumer Products Backpack Blower/Vac, Carb Logo
247 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
