Question about RCA F20645 TV
I have the TV above and the cable man came out to hook-up to cable TV and couldn't figure out how to get the cable box to work on the TV turner. He had to hook it up to the auxiliary jacks on the back of the TV. How can I hook-up the cable box to the TV turner and not the auxiliary jacks?
    President:
  • 1,285 Answers
Is there a coaxial cable jack in the back of tv..(if not you may need an adapter..hook to antenna)..then set the tv to ch 3 and set to cable broadcast not air. then you will use the cable box to tune to ch.
Posted on Jun 07, 2010
How do I hook up my 55 inch led tv to a stereo for better sound
In many cases newer tv's do not have an audio out, some have a headphone jack on the side (Small usually blue)
Otherwise if you are wanting to get better sound from a DVD / Blueray / Satellite / Cable box, You can put the audio from these devices into your sound system, then plug your sound systems audio out into the tv.
The video out from your devices will need to connect directly into the tv.
If using HDMI or S-Video that carries both audio and video, slitter / separation boxes are available, but usually degrade sound and audio quality.
The above would look something like
Cable box audio out (red / white) to Stereo audio IN. >> Stereo Audio OUT to TV audio in.
Yellow (Video) Cable from cable box then goes directly to the TV Video IN. Just make sure the audio and video cables are going to the same section (Some tv's may have multiple audio / video in's
Nov 17, 2014 | Haier LE55B1381 55 Class LED HDTV - 1080p,...
DOES THE SHARP T V MODEL lc46sb54u HAVE ADIGTAL TURNER, IF SO HOW DO YOU ACTIVATE THE TURNER
it has a digital tuner that also does analog channels. You dont need to active it. I fyou are trying to get the channels over an antena, go into the menu and do a auto scan for channels. Set the auto scan as "cable". If you are trying to get cable channels over 19 it wont work without a box. The digital channels are scrambled for cable.
Sep 09, 2011 | Sharp LC46SB54U 46 in. LCD TV
I can only get 2 channels on my TV hooked to Cable
Please do the Auto Channel Program once again and let me know.
Aug 28, 2009 | Westinghouse SK-42H240S Television
Dish Network Box, Technics Receiver, RCA LCD TV connections
I would use the s-video out & red & white rca audio out on dish box to s- video & audio in on the t.v., then audio out from t.v.(RCA, red & white) to one of the inputs (RCA) on the receiver.
May 25, 2009 | Technics SA-EX400 Receiver
It doesn't work on my laptop Vista Home addition
I think the problem is windows vista itself. This MSI product does not have drivers for vista...
You can try forcing the xp drivers, but it oriblably won't work.
Good luck
Oct 15, 2008 | MSI USB 2.0 TV Tuner (MSIVOX2)
No signal when hooked up with a digital cable box
turn your tv to channel 3 and then try 4 one of these should work . Also make sure that you have it plugged in the right coax jack in the back
-Josh
Mar 05, 2008 | Vizio L32 32 in. LCD HDTV
Tuner won't go above Channel # 99?
Most cable boxes that go past 99 are digital channels and require the cable box to tune them in. You can always set the cable box to the station you want and hookup the rca output to your DR4 rca input and record from that. Their is no other work around for this because the DR4 has an analog tuner inside of it and your cable box is a digital turner.
Dec 20, 2007 | Toshiba DR4 DVD Recorder
Hooking up cable through ht-x50
You need an Optical Audio Cable. Hook one end to the HD Cable Box and the other to your Surround Sound System. If you dont have an Optical Cable to your Cable Box, then try using the usual audio cables. But, I have HD and it worked with the Optical Audio Cable.
Dec 05, 2007 | Samsung HT-X50 System
Colors out of Whack on HD input 4 only
May need higher quality component HD cables? Tried switching Blue on Red? Just some thoughts.
May 02, 2007 | Philips 60PP9202 60" Rear Projection...
RCA F20645 TV Logo
140 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
