Question about AdobeAir WisperCool MMB8 Portable Air Conditioner
Overflow standpipe My overflow standpipe is leaking from the bottom. Where can I get replacement parts for my Model MMB8
  • 76 Answers
Lowes and Home Depot sell a generic standpipe. If it's too long it can easily be cut down to size.
Posted on Sep 13, 2010
What is the gas line coming out of the bottom of the carburator
yup to overflow. if its leaking you need to clean your float shutoff valve .
Feb 15, 2015 | GAS Motorcycles
Gas leaking from the vent tube on the gas tank
The standpipe sits in the tank and connects the filter "sock". The only vents, or overflows, should either be from the carburetors (overflow) or vacuum vent (typically found on dirt bikes) on gas lid. You should have no lines that directly "vent" from the tank. It is possible you have the wrong tank installed on the bike. Just a suggestion. ^^ I hope this helps.
Apr 14, 2014 | 2002 Harley Davidson XL Sportster 883
Drain stand pipe Washer fills and drains at same time. Manual says the drain stand pipe must be greater than 30 degrees. I would like to have a description of the drain stand pipe and it's...
30 degrees or 30 inches. The drain stand pipe is separate from the washer and usual plumbed in behind the washer. You bring the the drain hose up to the top of the standpipe and then push the end (forming an upside down U at this point) into the top of the open 2-3" diameter PVC pipe and secure it so that it won't back out (but do not seal the opening). Nylon ties or hose clamps will work. The height requirement is so that the bottom of the hose in the standpipe is above the water level in the washer - this avoids the drain siphoning the water out of the washer. Check how far into the standpipe the drain hose has been pushed. If it is below the level of the water in the washer, back it out. Check the height of the standpipe. Many washer manuals recommend a 34" standpipe (max height of 48") based on the drain hose length on the down side of the U. Also make sure no one sealed the top of the standpipe against air entering the pipe. (Often this is done because of a back up in the drain, pull the drain hose out and get the pipe cleaned out and then put the hose in to the proper distance. Then leave the top of the standpipe open.)
For a picture of the standpipe, see http://www.appliance411.com/faq/washer-drain.shtml .
There is a parts diagram for your washer itself is here: http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Washer-Parts/Model-GLWN5050M0WS/0432/0153200?searchedModel=glwn5050&blt= .
I hope this helps.
Feb 28, 2011 | Washing Machines
Washer standpipe was cut down approx. 12 inches and now I have overflowing. Standpipe is very old and almost impossible to remove and replace. What else can be done?
The drain pipe must have a restriction in it. Sometimes the build up sludge inside the pipe and that will need to be replaced
Jan 04, 2011 | Kenmore 20172 Top Load Washer
I have an electrolux front loading washing machine it is leaking water at the bottom and produces chunks of melted plastic during the cycle
Hello. If water is leaking from your washer, check the list below:
  • Is the drain clogged? If you have a clogged drain, it will need to be cleaned – contact a local plumber if necessary.
  • Is the drain hose restricted, or out of the standpipe? If the drain hose is out of the standpipe, you’ll need to secure it. You can do this by bending the end to form a hook, placing the hooked end into the standpipe, and tying the hose to the standpipe or a faucet with a cable tie (one was supplied with the washer), strong filament tape, or duct tape.
  • Are the fill hose connections loose at the faucet or washer? Check them and tighten the hose connections. If they’re loose, you might need to install or replace the rubber sealing washers.
  • Are you using a high-sudsing detergent or is your water soft? Using a high-sudsing detergent, or using too much detergent in soft water, can cause suds to overflow the washer. This may seem like a leak if the suds flow or drip onto the floor. Use a low-sudsing detergent and reduce the amount of detergent you use if your water is soft.
Apr 22, 2010 | HP DVD DRIVE DVD Drive
All of the water filling my kenmore washer is flooding out bottom
If you have ever experienced the problem where you washer continually fills but never reaches the proper level (not an overflow). Or, the wash tub water level cannot be maintained, because the water level keeps dropping. You may be experiencing what is known as "siphoning". This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
* The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
* The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
* DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
* DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
* The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 15, 2009 | Kenmore HE2 Plus Front Load Washer
Water continues to run into and directly out of the machine and thus does not fill up and advanve to next part of cycle? Can you help, PLEASE?
Jun 11, 2009 | Kenmore Washing Machines
Kenmore elite clothes washer model 22952
If you have ever experienced the problem where you washer continually fills but never reaches the proper level (not an overflow). Or, the wash tub water level cannot be maintained, because the water level keeps dropping. You may be experiencing what is known as “siphoning”. This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
* The standpipe should be a minimum of 34” from the floor, and should not exceed 72 inches in height.
Feb 01, 2009 | Kenmore 22422 Top Load Washer
Wont drain
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Plug off the wall & look underneath, a hose may have come loose. Check, replace or fasten.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
May 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leaking water from the Liquid chlorine bleach dispenser
Jan 12, 2008 | Kenmore 3.5 cu. ft. King Size Capacity Top...
AdobeAir WisperCool  MMB8 Portable Air Conditioner Logo
176 people viewed this question
Top AdobeAir Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you an AdobeAir Heating and Cooling Expert? Answer questions, earn points and help others
