Question about Toshiba 2060 Copier
Says to empty old toner. we have done that and
Says to empty old toner. we have done that and replaced with new toner. error will not clear
  • Toshiba Expert
  • 1,326 Answers
The copier is most likely saying to empty out the waste toner. It has been awhile, but I believe it is up front and to the inside right of the front door. It is a milky white container. You may have to open the paper trays to open the door that covers the bottle. I would empty it out very, very carfully and return it back to it's place and that should do it for you. There may be a reset code if the copier has a error code. Good Luck....
Posted on Jun 04, 2010
Sharp MX-M232D: F2-40 error. I was able to scan without issues. When I inserted a Sharp Genuine Toner cartridge into the machine, I receive an F2-40 error.
If you have reset the machine as described & then re--inserted the same toner cartridge giving you the same error code then I would suspect the CRUM chip that is installed on the toner cartridge is faulty.
If your machine is under a maintenance contract which includes the provision of toner then contact your service provider & they should replace it F.O.C. If you have purchased it yourself then contact the supplier advising them of a faulty cartridge. If you replace the toner with a new one, you must reset the machine as above before you insert the new toner.
Hope this helps.
Dave.
Oct 12, 2017 | Sharp Office Equipment & Supplies
How do I clear the 'dispose of used toner' error message?
Clean well the toner box or better replace with a new toner box.
Sep 24, 2014 | Toshiba Dp3580 Dp2570 Dp2460 3560 2060...
Hi Sir. I got a problem of my Toshiba e studio 3510c printer, when I swich on the button, the screen shows there is a sentence said ;'disposal of the used tonner', should I replace the wasted...
It said exactly what? If it mentioned waste toner, emptying that tray (Toshiba has nice zero-waste-to-landfill toner recycling program) should have pretty much cleared things up; it appears that the sensor for that still sees lumps of toner..or something...coming up close to the paper path. Check it out carefully and replace the tray.
Sep 10, 2011 | Office Equipment & Supplies
Toner problems with Konica Minolta 2450
very annoying message i agree - most likely caused by toner dust.
The printer uses a carousel to rotate the toner cartridges. Dust and toner can easily spill as the cartridges rotate. The error can appear at any time but seems to be most annoying after a paper jam or other error. It is also important to make sure that the cartridges themselves are clear of toner dust. Pay particulair attention to any copper contacts on the cartridge.
http://www.zinetic.co.uk/toner_refill/magicolor-sensor-errors.aspx
Jan 12, 2010 | Konica Minolta Magicolor 2450 Printer
Xerox Model 2515 Will not clear Toner Empty Stop Error
I had one today with a toner low light with new toner installed. Turns out they broke the green cartridge retainer clip.
The toner sensor pn# 130K45680 btw.
let us know if it was the sensor.
Aug 03, 2009 | Xerox Office Equipment & Supplies
Gestetner DCS424 error message: replace used toner bottle
There are 2 waste toner cartridges, be sure to empty these 2 cartridges . If you remove the waste toner in both cartridge it will automatically clear the error message.
Feb 27, 2009 | Gestetner Copier
DCS424 error message replace used toner bottle
Change k toner error message
If you want to use the toner cartridge after the printer decides that it's empty, you can do it by going into the Machine Settings in the menu, and option 8 (at least on my Magicolor 2590MF) says "Toner empty stop?". Just change that to NO, and you're set to go.
May 27, 2008 | Konica Minolta magicolor 2490MF Laser...
Unable to clear error
Have you replaced the K Toner? If so then rtry replacing it. It may be empty and the printer is monitoring a lack of toner in the delivery.
If you have replaced it and still shows it empty, the cart could be faulty. This is fairly common
May 09, 2008 | Epson Aculaser C1100 Printer
171 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
