Question about Dishwashers
Hi I have a whirlpool diswasher which is about 7 uears old which has blown the fuse (and the mains trip) half way through a cycle. Replaceing the fuse has resulted not resulted in the restoring of power to the unit. Is there anything simple I could check (in line fuses etc.)? Cheers
    Genius:
  • 1,073 Answers
Some whirlpool models do have a thermal fuse in the consloe mounted to the main control board housing, might looke to see if it has one and if it is good
Posted on Apr 10, 2008
Bosch diswasher,model Sms68m02AU trips circuit breaker
rcd units trip from the milliamps that are in a short
it trips the rcd to prevent electrocution and acts in nano seconds besides being a circuit breaker for excessive current
the trip can be from moisture allowing a current leakage to ground or some other simple operation
I suggest that you get in a qualified electrician / bosch service technician to find the reason for the problem rcd
Sep 15, 2016 | Bosch Dishwashers
I have a Whirlpool ADP9000ix diswasher that will not power the front display/touch panel. Therefore cannot turn the dishwasher on. I have checked the circuit control panel. And power is getting to it....
If your Whirlpools over there are like the older ones here in the U.S., you may find that there is a thermal fuse mounted just above the circuit board. If there is one, turn off the power to the unit, pull off the 2 wires connected to it and check it for continuity with a multimeter. If that fuse is blown, nothing works as it controls all power to the unit. Replacement fuse kits (at least here in the U.S.) are readily available on ebay for a fraction of the price that an appliance parts store would want. By looking on ebay for "Whirlpool dishwasher fuse" you can see what the fuse assembly looks like, and if identical to yours, purchase one. If you do buy one, follow the installation instructions exactly by using the supplied wires on the new fuse and the screw terminal block to make the connections. If you don't use the new wiring and connection block and simply plug the new fuse to the old connectors, it will simply blow again in a short time.
Jun 07, 2014 | Dishwashers
Whirlpool GH5184XPS-7 microwave oven dead, no power.
The problem is in the magnetron or the inverter board.
May 27, 2012 | Whirlpool Microwave Ovens
2001 durango r/t everything is wrong the raadio quit working the interior lights dont work the trip gauge resets itself the gas gauge dont work half the time the rear defrost dont work the drivers side...
Try looking at the fuses in the fuse box some of them might be blown and if they are then you probly have short somewhere in your car (replaceing the blown fuses might help)
Dec 26, 2010 | 2000 Dodge Durango
DISHWASHER HAS NO POWER. Was running then then stopped in middle of cycle.
The first thing to check is your breaker box to make sure the breaker did not trip. If that is okay then you may have a blown thermal fuse inside the control panel. I have put together some instructions on this repair. Follow the link and let me know if it was helpful.
Thermal Fuse
Jul 19, 2010 | Whirlpool 24 in. DU1055XTP Built-in...
No power and its not the breaker.
Some dishwashers have a thermal fuse located behind the console attached to the main board It is always helpful to include model number off unit as Sears does not make any appliances, they just sell them made by other companies with the kenmore name on them. You could have a GE, Whirlpool, Frigidaire, etc....
Mar 13, 2010 | Dishwashers
My washer stopped in the middle- and wont turn back on- full of water right before the spin cycle! I have checked the breaker, unplugged it, pulled the knob and tried to recycle it- NOTHING! it is only 7...
It doesn't work at all If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Jan 19, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Beaumatic Diswasher
It could be that the heater is faulty - or the trip switch is worn out causing short cycling.
Does it sound like it is heating properly and getting on with the job - or does it sit for a long time doing aparently nothing?
Could also be the timer / programmer is mechanically damaged, or a component on the main control board, but most likely a heating issue.
Aug 05, 2009 | Dishwashers
The heat on our 2 year old Cabrio dryer just stopped working for no apparent reason. Everything but the heat appears to be functioning normally. Help!
Thermostat controls heat. There is also a motor centrifugal switch, in the element circuit, that the motor closes to insure the motor is turning. Try another heat setting. There is more than one thermostat. You may have blown the 'thermal fuse' too, which requires replacement.
It is possible that your element has failed also.
Tripped high limit. Must clean the lint filter and the exhaust vent tube and all the way in to the dryer. Hot air exit is restricted.
Jul 18, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Nov 04, 2008 | Zanussi ZWD1680W Front Load Washer / Dryer
Dishwashers Logo
77 people viewed this question
Top Dishwashers Experts
