Question about LG WM-2277HW Front Load Washer
Oe code, i need to clean the black hose on the bottom of the washer how do i do that. thanks
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. OE is a drain error, it flashes when the washer won’t drain within 10 minutes. TO resolve this issue you’ll have to check the drain pump filter for any clogs, also check the drain hose for any kinks and clean the drain pump filter. If still the issue is not resolved then you might have to replace the pump. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 03, 2010
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: LG front load washer OE error. cleaned filter need
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!
Posted on Sep 18, 2010
Machine gets stuck in rinse cycle - sometimes gets OE code sometimes not.
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter located inside the front bottom for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Apr 16, 2011 | LG WM2455 Front Load Washer
Wont spin
"OE" code in your washer indicates a Drain error. This is because the washer is not fully drained within 10 minutes. You have to check whether there is a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge.
Thank you !!
May 25, 2010 | LG WM-2277HW Front Load Washer
What does oe mean on my washing machine display
Thank you !!
May 23, 2010 | LG WM2487H Front Load Washer
I am getting an OE code on the display. I changed
Make sure you check to see if anything is caught inside the drain line, or the bottom bellow (black hose that connects from the tub to the drain pump/motor.)
Mar 25, 2010 | LG WM2487H Front Load Washer
Clean Filter?
There is a filter at the rear of the washer.
Remove lower rear panel.
Remove large black hose from bottom of drum.
Remove and clean filter in inside hose.
Remove hose onto pump and check for blockage oe obstruction here as well.
Please rate my solution.
Thankyou.
Jan 27, 2010 | Hotpoint -Ariston Aquarius WD645 Front...
My washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Jan 18, 2010 | LG WM-2277HW Front Load Washer
Jan 02, 2010 | LG WM-2277HW Front Load Washer
I have an OE code on my WM1814CW LG Washer
OE code - Check for clogged drain filter on end of hose, bent or clogged dain hose. Make sure hose doesn't go too far down drain pipe.
Hope this helps
Bob
Jul 06, 2009 | LG WM1814CW Front Load Washer
Oe error code
OE-pump blocked. Disconnect the power before attempting any work. Use of an RCD (plug in power breaker) is recommended.
Disconnect pump from sump hose and check for obstruction in either item. Pump removal: power off, remove cover, locate pump, (attached to other end of drain pipe).undo 2 wiring connections, 2 hose connections, and pump mounting screws. Remove pump chamber - some are held in with screws, others clip into place. Check for foreign objects round the impeller. If pump chamber is clear, may be a fault with the pump motor - in which case, replace.
Also check the filter - generally located behind a panel at the foot of the machine.Some are obvious like little square hatches and some are hidden behind the trim panel at the foot of the machine. Once panel is removed the filter should be visible. Its generally a circular plastic fitting which unscrews in an anticlockwise direction. Some hotpoint, indesit and ariston filters are located in the big black sump hose (the one that leaves the bottom of the outer drum and connects to the pump). Remove the back cover, locate hose, remove the tensioner clip by squeezing the tabs together, remove the hose, take out filter and clean.
Feb 06, 2009 | Maytag EPIC MFW9700S Front Load Washer
LG WM-2277HW Front Load Washer Logo
180 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
