Question about Kidde PE120 Hardwire with Battery Backup Photoelectric Sensor Smoke Alarm
Kidde pe 120 photoelectric sensor smoke alarm emits 3 "beeps" with a pause and then repeats until the 9vdc battery is removed. The house is not on fire and the 120vac power is connected. What might be the problem?
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 93 Answers
The 3 beeps, known as temporal pulse, is indicative of an alarm condition. If it stops without a battery, then the unit either does not have power or is otherwise defective.
Posted on Nov 20, 2014
frcs68
  • 1605 Answers
SOURCE: 1 chirp every 30 seconds
it is not the battery problem, you need to get a replacement.
the circuite board is bad.
Posted on Dec 02, 2008
szanti
  • 36 Answers
SOURCE: kidde nighthawk Carbon Monoxide & Smoke Alarm single beeps
If detector is more then 5 years old it will beep every 30 seconde to wirn you the sensor in the detector needs to be replaced. bying a new detector would be better.
Posted on Sep 28, 2009
szanti
  • 36 Answers
SOURCE: KIDDE Nighthawk Carbon Monoxide alarm beeping
If detector is more then 5 years old it will beep every 30 seconde to worn you the sensor in the detector needs to be replaced. bying a new detector would be better.
SOURCE: kiddie fire alarm model I12060, beeps once every
This happened to me, my smoke detector started chipping so I changed the batteries. A few seconds later it started chirping again. The answer is in the way you put the batteries in. The smoke detector allows you to put the batteries in wrong and makes a slight connector. This slight connector tricks the detector into thinking the batteries are weak. Simply turn the batteries around so the fat connector of the battery touches the skinny connector of the device. Mine was, fat side on the right.
Posted on Feb 28, 2010
  • 13 Answers
SOURCE: kidde smoke alarm won't stop chirping
Most smoke detecotrs have a limited lifespan of 5-10 years. On the underside of the detectors should be a sticker with installed dated or replace by date. If changing the batteries doesn't stop the chirping it is most like time to replace the detector. If you check the manufacturer website they will give you a life expectancy for your detector.
Posted on Mar 23, 2010
My alarm beeps at night for a short period
if it is about a smoke alarm with a battery in it, when the alarm beeps for no apparent reason, it is a bult in indicator that the battery is flat or approaching a low voltage and needs replacing
If it still beeps after replacing the battery have it checked out as a fire alarm is critical for your safety
Jun 12, 2015 | Kidde 1276-9995 Hardwire Smoke Alarm with...
Open brooks smoke alarm to change battery
Hi Robin
Usually push in (up) & turn
Feel it as you turn
.....then remove from other half.
Have 9v battery handy for replacement.
Mar 05, 2015 | Brooks Kidde 120 VAC Photoelectric Smoke...
My Kidde carbon monoxide alarm keeps beeping every 30 seconds and we have put new batteries in it but it keeps beeping
Detecotrs have a limited lifespan of 5-7 years. So sounds like you need new one (Its not worth to buy just a sensor). Take a look on amazon Amazon com smoke alarm detector (watch out on reviews). I hope this was helpful. cheers
Jan 09, 2012 | Kidde Carbon Monoxide (KNCOBB) and Smoke...
I just replaced 3 old interconnected Nortron AC 12W smoke alarm with 3 kidde direct wire 120V units- ( no battery back-up) when i turn the AC breaker on- all three Kidde chirp every 10 seconds. I ...
The Kidde website does have a lot of manuals but you need the model number. Try going to this URL, then browse by subject. You'll probably find the answer there.
Jul 24, 2011 | Kidde 120-Volt Front Load Battery Smoke...
Our hard wire smoke detector model i12060 just beeped really lound a few times and stopped, it glows green and flashes red every few minutes?
Change the 9V backup battery,with a new one.Push and hold the reset button for a minute or two for the alarm to to go off like about 30-40 sec. for the smoke detector to dectected the 9V backup battery power sourced.The green power LED light indicator will stop flashing also the beeping sounds too.
Jul 12, 2011 | Kidde 120-Volt Front Load Battery Smoke...
Hello I have a KIDDE FYRNETICE smoke alarm.
According to the Kidde website, this unit was discontinued in 2010. If the unit is more than 10 years old it must be replaced per NFPA 72 (assuming you live in the US)
Dec 22, 2009 | Kidde 1275 Hardwire Smoke Alarm with Hush...
My first alert smoke detector went off at midnight last night. It is doing the three beeps, pausing and then another three beeps. This happened for about 3 minutes, stopped and then started again...
Change brand new battery,every three months.Take some rubbing achahol clean the test button metal contact inside the detector.Well works correctly after these steps.
Dec 15, 2009 | First Alert SA302 Dual System Smoke...
My alarm and smoke detector keeps beeping a single beep every few minutes
Ours keeps chirping even after we replaced the battery. I'm not sure how to fix it.
We are going to try and clean it but if it keeps doing it after that then I guess it means it needs to be replaced, right?
Nov 26, 2009 | Kidde 120-Volt Front Load Battery Smoke...
I have the model 0916. It beeps every 40 seconds
Manufacturers recommend replacement every ten years. Could be dirty? Is it connected to the ac house power?
Aug 03, 2009 | Kidde 0914 Battery-Operated Ionization...
I have 3 of these alaems and 1 keeps beeping
Replace all batteries with the exact make and model listed on device.
Jul 12, 2009 | Kidde 0914 Battery-Operated Ionization...
Kidde PE120 Hardwire with Battery Backup Photoelectric Sensor Smoke Alarm Logo
734 people viewed this question
Top Kidde Home Experts
Tre Elkins
Jim Goldsmith
Jim Goldsmith
Are you a Kidde Home Expert? Answer questions, earn points and help others
