Question about Apple eMac G4 Desktop
EMac won't start
After a power outage, my old eMac would not start. I flipped it over and took off the panel and hit the little button with a paperclip like I have before to restart it but this time...nothing. Any suggestions?
I know this is an old machine but there is some important stuff that I need still on it.
  • rberner691 Jun 05, 2010
    By the way, I took the machine into an Apple store and found out that most Macs have a circuit breaker inside. If you unplug from a power source for about 5 minutes and re-plug...comes right back on...no harm...no cost.
    Maybe you should brush up on Macs.
  • 787 Answers
You need to have its power supply changed. It would be best if, in this case, you would take it to an authorized electronics service. Once it will have a new power supply, you will be able to access your data without any problems.
Posted on Jun 03, 2010
  • 2 more comments
  • rberner691 Jun 03, 2010
    Sounds expensive...it's been a while since I had the Apple Care coverage on this machine.
  • Tudor Valean
    Tudor Valean Jun 03, 2010
    If you take it to a regular electronics service, not Apple, it should be really cheap since it's not complicated.
    Not many alternatives with this one, eh?
  • Tudor Valean
    It's a Mac ... unfortunately, no.
Need to reset as it is stuck on ready in 1 hour which we did not press. Tried letting it run but still stuck and no washing.
Hello. I really need the model number and make of the unit to help you most accurately. From what you describe, it sounds like the control panel might be defective. Also, the main board could also be corrupted. Have you had a power outage recently--about 3-4 weeks ago or sooner? Outages are NOTORIOUS damaging digital boards in appliances. The fact that you didn't press anything might mean that a button on the panel is shorted. However, to try to reset the board, try removing power from the unit by flipping the associated breaker in your power panel to off for about 2 minutes. Turn it back on afterwards and see if the unit will start. Let me know if you need further assistance. Thanks!
Nov 29, 2015 | Dishwashers
My Dell W3707C LCD TV won't quit flipping. The only button that works is the power button. I can hold the channel button down and flipping stops for about 2 minutes and then it starts flipping a
one of two basic things here, unplug set to see if after a while it helps, and if channel scanning up or down on its own suspect the button associated with the direction it changes is a bad one.
Oct 29, 2012 | Dell W3707C 37 in. LCD Television
Our Ruud ac won't come on after a storm and power outage? I have flipped the breaker with no luck. Any suggestions?
there is a fuse on the circuit board on the inside unit. Typically a power surge will pop it. checking that fuse is the best place to start
Sep 29, 2012 | Ruud Heating & Cooling
My dell d600 doesnt start after a power outage. It was plugged into a power surge protector. This has happened before (power outages) and never a problem. After this outage, I was able to get online for...
A little googling gave me this http://www.laptop-junction.com/toast/content/dell-caps-lock-light-flashing-blinking
Looks like it could be a memory problem. You could check if one or both of your memory is damaged by removing one at a time. The manual should have the procedure for adding / replacing memory.
Feb 21, 2011 | Dell Latitude D600 Notebook
Blacked out screen
If the power light is blinking amber – The computer is receiving electrical power, but an internal power problem might exist.
Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
Ensure that the processor power cable is securely connected to the system board (see page 73).
flip off the surge protector and then flip it back on.
Jan 26, 2010 | Computers & Internet
Gateway M520X Plus will not power up?
This is a sample of what you can try to do to diagnose a non-starting computer, If these don’t work, realize that most likely a system board (motherboard) has failed or the actual power trim strip above the keyboard has failed.
  1. Unplug the computer, then take the battery out, push the power button and hold it for about 30 seconds. Plug the system back in (leave battery out) and push the power button. If it starts, Great! If not unplug go to the next step.
  2. You should still have the battery out and the power unplugged. Now turn the laptop over. Take off all the covers and pull out the hard drive and ram and wireless card. Find the screw that has a symbol kind of like this its the CD rom drive screw. Now pull the drive out. Pick one stick of ram and put it back in the computer. Flip it over open it plug it in and hit the power button. If it does not fire up then unplug it and switch the ram. Plug it back in and hit the power button again. If it doesn't start up, unplug the computer and go to the last step.
  3. Pull the memory out and find the screws that hold the keyboard on. There are symbols in the plastic there should be 2 screws holding it in. Now in the battery compartment, there are several screw at the back edge of the computer take them out and also the ones in the battery in the center strip. Some are silver and some are black. Once you have the screws out of the battery area flip the computer over and open the lid. The strip just below the LCD with the power button and controls will now be able to be lifted up. You will probably have to lightly get an edge started before it will come up. There should be several little cables hooked to it. Flip the control panel over and look for some screws holding the keyboard in. I think there's 2. Lift up the keyboard. Making sure there's nothing touching anything important and then plug the computer in. Carefully hit the power button and see if the computer tries to start. If it does try it will probably beep at you. Unplug it and put a stick of ram in it. Plug it in and try to start it again. If not, unplug the computer and Go to the next step.
  4. Carefully put the keyboard and control strip in place. Flip the computer over and loosen all the screws that hold the computer together. Flip the computer over again and pull the keyboard and control strip up again. Flex the inner aluminum plate that was under the keyboard lightly. Plug in the computer and then hit the power button. If it tries to start, Great! put it together again in the reverse process.
If it does not, there are 2 possible things I would suspect the Control strip or the mainboard. If you don't get the computer to start back up please put it back together so you remember where all the screws go. Even if you plan to get another mainboard put it back together.
Nov 08, 2009 | Gateway M520X Plus PC Notebook
Ok i have an hp laptop that was on an update and then the power turned off of no more power. Now i cant turn it on and i dont have a Operating System disk.
These are just a few steps to take....since there is not a whole lot to go with. we'll just try it a little at a time.
  2. You should still have the battery out and the power unplugged. Now turn the laptop over. Take off all the covers and pull out the hard drive and ram and wireless card. Find the screw that has a symbol kind of like a circle with a wedge cut out, it’s the CD rom drive screw. Now pull the drive out. Pick one stick of ram and put it back in the computer. Flip it over open it plug it in and hit the power button. If it does not fire up then unplug it and switch the ram. Plug it back in and hit the power button again. If it doesn't start up, unplug the computer and go to the last step.
Oct 10, 2009 | HP Pavilion dv6000z Notebook
Camera software corrupted??
I had the same problem with my flip mino HD. Here are the steps I took to fix it.
1. Adjust the power options on your laptop to ensure it does not sleep/hiberate ever.
2. Reset the camcorder by inserting a paperclip into the hole in the tripod mount. Hold the paperclip in there for about seven seconds.
3. Then immediately plug the flip into the cpu.
4. You may not see anything besides the little blinking white light on the USB arm for a while (about 30 minutes maybe) but leave it in.
5. Eventually it should spring to life and show the recharging battery on the little screen (the Flip Share program may start too.)
6. Leave it charging until the little white light stops flashing - full charge about 3 hours.
7. You can then remove the flip and change the power settings back to normal.
Apr 13, 2009 | Pure Digital Flip Video Ultra Camcorder
Removing outer shell of emac
Lift the housing up 4 " pull off the power button cable on the housing side. reverse.
Jerry
May 09, 2008 | Apple eMac G4 Desktop
Apple eMac G4 Desktop Logo
93 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
