Hi
Thanks for using FixYa. To start
with check the water line attached to the back of the
refrigerator for good water flow. To do that, first turn off the water supply
valve. Then remove the water line from the back of the refrigerator. Next,
place the water line into a bucket and momentarily turn the water valve back on
to test the flow. If the flow is poor, you need to repair, clean, or replace
the tubing or the shut-off valve that supplies the water. If the flow is good,
you may have to replace the water inlet valve. If still the issue is not
resolved then remove the ice bin, Remove the wires from the auger motor.
With the freezer door open and the door switch depressed, push the ice cube
release and check for 120VAC between the motor wires. If there is 120VAC then
the motor has gone bad. If there is no 120VAC then the control board (module
time delay) has to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
