Question about Dometic Rooftop RV Air Conditioner
Air conditioner does not stay running.
When you turn on air conditioner it will run for 15 or 20 minutes and than the fan and the cooling stops and all you can hear is a humming sound. please help!
    Top Expert:
  • Dometic Master
  • 8,163 Answers
Bad motors fan or compressor or both
Posted on Sep 15, 2017
4 Suggested Answers
plnolte
  • 62 Answers
SOURCE: AIR CONDITIONER MAKES BUZZING OR HUMMING SOUND
Yes probable you may need a new fan motor but check the capacitor first.
Posted on May 12, 2009
louislevel_2
  • 374 Answers
SOURCE: Samsung Ac compressor stops after 20 minutes and fan keep running
eventually,cycling process is doing done if the thermostat sense the configure temperayure set up it will trigger to stop your compressor motor as well as the blower fan,blower fan independenly to you compressor.if your thingking that your compressor is tripping off,check your operating current on one line using clamp ammeter and compare to the rated current that tag on
motor compressor body,if the current flow is higher than the rated current specified on compressor motor,well problem occured it will trip your compressor,because overload protector is becoming your thermostat.but if you got same current result it was cycling process.If tripping off maybe air is present in your system call qualified ac tech, to purge out air in system.
Posted on Mar 16, 2009
  • 588 Answers
SOURCE: RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Posted on Jun 09, 2009
My 2003 VW Jetta air conditioning is cooling for a few minutes and sometimes longer and then it stops cooling. The fan continues to run but the compressor apparently stops running.
Have you watched the compressor in action? The compressor is driven by the fanbelt which turns a pulley on the compressor shaft, but there's an electric clutch that disengages the pulley from the friction plate attached to the compressor shaft. You should hear a click when the clutch engages and disengages. Do you hear that? Can you see the friction plate turning with the pulley or does it stay in one position while the pulley turns? If if works for a bit then stops turning, you may have a damaged friction plate such that it doesn't engage with the pulley. Take your car to an auto A/C specialist and let them examine it. It's also possible that the relay that sends 12 volts to the clutch is intermittent and needs to be replaced.
Jul 22, 2015 | Heating & Cooling
Indoor fan will not stop
Seems like the fan relay has stuck (Likely to be on the main indoor PC board) or if the machine was being used on heating mode, the indoor pipe sensor may have failed causing the fan to continue to run. Most air cons on heating mode, will keep the fan running for a few minutes after you switch off on heating mode to cool down the indoor unit before it turns off completely. The pipe sensor signals the main PC board to tell it that the unit has cooled down and can now turn off completely. If either of the above faults occur, the indoor fan will keep running all the time.
Jun 19, 2014 | Goodman CKL36AR36 Air Conditioner
Compressor stops running.
in dehumidifier modes work like in cool mode..try in cool mode too see if it work
Nov 30, 2013 | Haier CPN14XC9 Air Conditioner
Unit cools for a few minutes then stops cooling. Even fan stops blowing air but the unit remains 'on'
unit may be short of gas. will run for a few mins before low pressure switch turns the compressor off. you will need to get an engineer to check gas pressure
May 21, 2010 | Samsung AW1003M Air Conditioner
Compressor continues to run for another 5 minutes after the fan has stopped. Air conditioner cools fine.
sounds like the "extended run timer" is somehow hooked to the compressor circuit instead of the blower fan circuit. This may appear after installing a programmable or digital thermostat. check configuration.
May 16, 2010 | Dometic Rooftop RV Air Conditioner
Jun 06, 2009 | Dometic Rooftop RV Air Conditioner
Air conditioner fan problem
Take a brush and clean it, then oil it.
Jun 01, 2009 | Carrier Heating & Cooling
Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
Out air compressor fan runs for about five minutes then the fan stops turning unit is about 5yrs old
if the compressor stays on for a short time after the fan stops most likly the fan motor has problems could be capactor or bearings dan
Jul 17, 2008 | Heating & Cooling
Blower starts ans stops
May be a short in the wiring or a bad control board.
Jul 07, 2008 | Goodman CLQ36AR49 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
204 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
