Question about JVC HD-61FN97 61" Television
Spot's on tv screen's
Spot's on tv screen
  • 505 Answers
If the spots are coin sized or so, its likely dust. These tvs are know for dust particles getting on the len inside and causing issues. The tv needs complex disassembly and cleaning to solve the issue. The only tool required is a philips screwdriver but it does require some know how. A air compressor or can of compressed air is helpful also. Let me know if I can assist you further, the directions could be quite lengthy. Thanks
Posted on Jun 03, 2010
Anyone knows where white spots on the screen along the bottom of the tv screen can be coming from
The spots are part of the transmitted signal. Normally they are masked so you don't see them.
Aug 16, 2016 | Sharp LC 70SQ15U 70 inch Aquos 1080p
Sanyo dp42848 black spots and scrambled screen
Black spot means the LCD panel is faulty. Its better to go for new tv than rearing this one.
www.electro-medical.blogspot.com
Oct 07, 2015 | Sanyo DP42848 LCD TV
One yellow, one pink, and one blue spots appeared on my tv screen.
The set if projection which model here is, has arced and now each of the three picture tubes used has a tiny permanent burn mark on its screen.
That is what you are seeing, the set uses three picture tubes with screens like the old tv sets===the coating has been burnt in each, want to prove it, remove rear cover and cover any one of the three lens and that mark on one tube will go a way.
Not fixable.
Dec 23, 2012 | Mitsubishi WS-55315 55" Rear Projection...
Blue pixelation spots all over main viewing screen.
Your dlp chip needs replacing. It's a job to do but you can do it.
Jul 23, 2017 | Sony Video Cameras
I have a brown spot in the corner of the tv on the screen it almost looks like a water spot. Can this be repaired..
No,these problems are called a bruses or dead pictures pixels spots.These problems are only can causes by outer forces did some harm to the tv LCD screen panel itself.Sorry this problems can't be repair only can be replace like the whole LCD screen panel itself.Not pratical,save ur money buy a new tv.
Aug 31, 2011 | Protron PLTV-32 Television
My plasma tv has blue or black spots (scattered on tv screen) when it is on about 30 mins to 1 hour then as it on for long hours it becomes black spots and covered whole screen
I am facing the same problem with my LG 32 inch plasma TV. There is also a big 2inchX4inch oval black spot at the top centre of the screen. Please suggest any remedy and also the cause. mbkhurshid@gmail.com
May 17, 2010 | Televison & Video
Couloured spots on screen
Hi
sounds like you have colour impurity problems caused by a magnetic feild being near the Screen. Fist check for any new magnetic feilds nearby. If there have been no new changes, it may also be a faulty PTC device that automatically degausses the tube. When they fail, you will get problems with impurities by way of coloured spots on the screen.
Try disconnecting the set off at the wall for 30 mins, this will initiates the auto degauss process. If all is ok, the spots will be gone. If not, you will need to have someone handy with a soldering iron that is also familiar with TV repair to replace the PTC for you.
Please rate this solution. Happy to answer any other questions you may have. Cheers.
regards robotek
Jul 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Large yellow spot in center of tv screen
Sorry, but there is no cheap method of repair for this unless it is in warranty.
This TV will require replacement of the LCD Prism unit.
This Prism blocks and allows colors so that the 3 LCD images may be mixed to produce the final image you see on the screen. When this becomes damaged or defective, it leaks colors (light). This Color Leakage apears as spots on the screens.
Where you see the spots is where the specific spot on the prism that is leaking light, the specific color that is leaking also.
This parts cost alone is normally $500 to $1000 dollars but is usually replaced under warranty.
Good luck.....
May 18, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Olevia TV white spot on screen
U should not get such type of white spots on the screen
call ur experts..
thanks..
Feb 01, 2009 | Olevia LT37HVS 37 in. LCD HDTV
How to clean the "wet spots" off my TV.
the liquid is between the lenticular and fresnel
they are most likley damaged and will have to be replaced...
Oct 18, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
JVC HD-61FN97 61" Television Logo
248 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
