Question about Campbell Hausfeld Air Tools & Compressors
I have a Campbell Hausfeld 4 gallon, HL5402, won't start or hum
I have a Campbell Hausfeld 4 gallon, HL5402, 2 years old, approx 3 hours run time. Used one day OK, tried to use next day doesn't work. Took control cover off: 120 volts on line and motor side, can turn the fan (slight resitance) with a pencil thru the fan guard. Is there another 'control' under/close to the motor? What next? Access the motor leads and check for continuity on the windings??
I have exactly the same problem.... any helo yet?
Posted on Sep 19, 2010
Why does oil shoot out breather when I turn it on?
If the oil reservoir went dry, this will cause excessive heat and wear on the piston in the compressor. Once you refilled it, air now slips past the overly worn piston and blows oil out of the breather. This escaping air is the reason why the compressor will not get to more than 50 psi. You will need to repair (rebuild), or replace the compressor. Running it out of oil killed it.
Aug 09, 2015 | Campbell Hausfeld HL5402 4-Gallon...
My campbell 0.33 runs but won't built a pressure
Check that the drain cock on bottom of tank is shut off,or leaking.?
Jan 28, 2013 | Campbell Hausfeld 0.33 HP 2-Gallon 100 PSI...
Need a motor mine fried. Can just the motor be replaced?
Campbell Hausfeld, as I've seen over the years, makes a pretty middle of the road product and in my experience would be more expensive, what with shipping and all, to repair, than to replace
Nov 04, 2010 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
I have a Campbell Hausfeld PL1502. Air flow from the compressor is good, it won't go forward or backwards, won't even try. Air just whistles through it. I took it apart and didn't find anything obvious,...
oiling thing? thats the easy part,,its oiled every time you use it,
now it wont start then,,,ok its jamed up or the air flow and presher is to low for it,,,look under the handle were the hose fits to the gun there should be a big screw there on this screw there should be 1-2-3-4? turn it to 4,,now try it???
Aug 18, 2010 | Campbell Manufacturing Campbell Hausfeld...
Campbell Hausfeld extreme duty 4 gallon air compressor, when running won't switch off?
check for a crimped or damaged line going to the presure switch or it might b the presure switch itself
Oct 17, 2009 | Campbell Hausfeld 04 Gallon Twin Stack...
Campbell hausfeld mod wl611700aj runs for 3-5sec
If the motor isn`t bad,then the one way (check valve )is not working,putting to much pressure on the head.
Oct 05, 2009 | Campbell Hausfeld 28 - Gallon Air...
No air pressure past 60PSI on a 125PSI Campbell Hausfield WL61110
Your comperssor is oilless type and suffers from short cylinder / piston life. When the compressor no longer reaches cycle pressure the cylinder / piston should be replaced. These parts are available at www.chpower.com I believe that the part number is wl210300aj. Not expensive, enjoy.
Dec 13, 2008 | Campbell Hausfeld 26 - Gallon Air...
Air Tools & Compressors Logo
349 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
