Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
Direction of fuel filter for Poulan Pro Riding lawnmower
I am replacing my fuel fiter and need to know the direction that it needs to be placed. Fuel filter is a Briggs & Stratton Part # 394358S. Online instructions say that arrows should point toward carburetor. There are no arrows on filter. There is a larger diameter end and a smaller diameter end. The filter is identical to original but I had changed to one that was suppose to be a replacement part from Sears. I can't remember how original was placed.
  • 36 Answers
The small end should point to the carb
Posted on Jun 03, 2010
Ride lawnmower
bad check valve can do this also bad pump but i would say check valve is bad and chang hydrstatic oil and filter probably really dirty oil
Sep 01, 2014 | Poulan Garden
Where is fuel filter
You will rarely if ever have a fuel filter on a push lawnmower. It may be that because of the fact that fuel consumption is very low, a filter would not be easy to incorporate into the system. Consider being sure that you start each season with fresh fuel and you should not encounter any problems. Leaving old fuel in a tank at the end of the season can prove to be very damaging and troublesome.
Jun 29, 2014 | Poulan Pro 22" Self Propelled High Wheel...
I have a 18.5 Poulan Pro riding lawnmower that runs fine untill I activate the blades. It then dies after mowing for a few minutes. I disengage the blades and it runs fine. Any solutions?
does it loose power then die or just shut off?does it run rough then die?try and run it with the gas cap loose th event could be plugged and the extra fuel needed to mow the vent might not be keeping up or a plugged fuel filter
Jun 06, 2012 | Garden
I have a Poulan Pro lawnmower with 5.5 briggs that has been in storage for a few years. When i started it today it runs but the engine surges. Why is this.
There is a gasket/diaphragm between the carb and the fuel tank that has dried up and cracked and will need replacing. Model #: 5083D.You can purchase the replacement at Lowe's for $3 (Item #: 219691). Here are the directions for DIY:
Oct 04, 2011 | Briggs & Stratton Briggs Stratton...
212 JOHN Deere riding lawnmower starts a couple of put puts then quiits. Gas goes in the line and have put on a new spark plug. Still does the same thing.
Good day. Try replacing teh fuel filter and teke note of the direction of flow. Also get yourself a tin of carburettor cleaner and spray everywhere into the carburettor. Hope this helps
Jun 13, 2011 | John Deere 22HP Hydrostatic 42" Riding...
What is the rotation direction of a Poulan Pro PPB250E 31cc 17-inch Gas Trimmer, replacing the head and need to remove original
hold the head & undo the unit in a clockwise direction because arbor or adapter is left hand thread
should be so,e means of stopping rotation of shaft so can undo head - may be place a small rod in the hole to stop adapter plate rotation -
remember normal thread left y loosey - righty tighty
but with left hand thread opposite applies
left - tigthen , loose - right
cheers
Aug 14, 2010 | Garden
Poulan Pro 20hp Tractor with B&S fuel flow problem
sound like to m e that your gas cap is bad if its not venting it will do that
Apr 16, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Changing the fuel filter
Starting at the fuel tank.. follow the fuel lines towards the front of the car. Make sure when you replace the fuel filter that you put the arrow on the fiter the right direction, otherwise there will be no flow and the engine will not start,
Good Luck!
Dec 14, 2009 | 1996 Nissan Quest
I need info on a Poulan Pro 445 fuel line routing
I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
The fuel system routing is terrible, but it is all there is.
Fuel Routing follows:
Tank to carburetor (hose in tank with filter on free end)
Carburetor to primer (primer draws fuel from the tank through the carb)
Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
Lou
Oct 11, 2009 | McCulloch 10" Electric Pole / Chain Saw
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
496 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
