Question about Sony PlayStation Portable (PSP) Console
I was charging my psp when I decided to change it to another room,it was still hooked up and all so i just pulled the plug out of socket and i dropped my psp on the carpet nothing broke but now it won't turn on and i'm charging it and it stops charging its green but then it goes back to red status.
  • 81 Answers
Stop charging and leave it alone for a few days
Posted on Jun 03, 2010
My psp 1001 is not charging. i plugged it in the socket when the power generator at my home was running and the psp stopped charging after the generator stopped and power shifted to the mains.
hello, try charging it threw the USB port and see if that works, if it does, then you know that the psp isnt the problem. It can be your charger or you may need to replace your battery.
Apr 24, 2010 | Sony PlayStation Portable (PSP) Console
Tip
2005 Toyota Highlander_Change spark plugs
I agree with the previous answer that this a very time consuming job. It took me 2+ hours. I would correct a couple of statements in his answer. He refers to reaching around and behind an exhaust manifold while changing the plugs, but actually if you are working from above the engine (not below) you will be reaching around and behind the intake manifold (not exhaust) during this process. <br /> As he said, the front 3 are very easy - just remove the plastic cover plate and the coils are visible - remove one short bolt, pull the coil off, and using a long extension and a spark plug socket with a rubber insert you can remove the plugs and replace with new ones. <br /> The back 3 are very, very difficult. I did look from underneath the <a href="http://wiki.answers.com/Q/How_do_you_change_the_spark_plugs_in_a_2002_Toyota_Highlander#">car</a> and I don't see any way to get to them even if the exhaust manifold was removed. I do believe the best way is from the top. As the previous answer related room to maneuver wrenches and your hands / fingers is very limited. I did remove a couple of minor brackets and hoses and the cruise control wire to get a little more room. Of course, as with the front, you have to remove each individual coil. Also - I believe two tools are critical. First - a small size "stubby" ratchet with a flexible head. You CAN use this type of small flexible ratchet to do the removal and install instead of all finger movement. Second - you need a number of small extensions.... in the 1" - 4" range... why??? because the rear plugs are also "deep" but there is no room to feed a single long extension down between the firewall and the engine head. So - you have to feed the spark plug socket and one short extension, and then feed in another one, and then a 3rd one if necessary until you get enough length to connect the socket to the plug, and the top extension to the ratchet. To remove the extensions - work in reverse.. pull the "assembly" out a little, remove one short extension, pull out further, remove another, etc until you get to the spark plug socket. On the 3 rear plugs - for two of the plugs you work from "your right" side of the intake manifold, or from the driver's side. For the final plug, on the passenger side, work from your left side of the intake manifold. On both sides remove minor hoses or brackets to get a little more room - just be sure to hook them back up.<br /><br />
on Jan 26, 2011 | Toyota Highlander Cars & Trucks
My psp won't charge. Do I need to buy a battery?
NO! all you need to do is check the charge hole and see if it has any dust or dirt in it.if not check the wires to see if any are split.if not there must be somthing rong with either the cords/the socket your plugging it in to,or the battery itself.
Feb 21, 2010 | Sony PlayStation Portable (PSP) Console
Psp won't charge when plugged into computer
u cant charge on a computer unless you have a charger that hooks up to it...are you sure your using a charger or are you using the cord that transfers data to ur psp! the data cord will not charge ur psp its not a charger all it does is transfer data sorry you need a charger for the psp not a data cable
Jun 18, 2009 | Sony PlayStation Portable (PSP) Console
Psp sont charge.. new battery
try a new charger if that dosnt work take it into a shop that sells them and try ask them if they no wat to do
Jun 15, 2009 | Sony PlayStation Portable (PSP) Console
Power Problem with my psp
Make sure the plug is all the way in the socket, and make sure it's plugged into an outlet. If those are bouth done. Are you sure it only charges for the 3 minutes? maybe it's full by the time th elight goes off. Uhhh I'd say it's probably something wrong with either the things connecting the battery to the PSP or, the female end of the power connector. Damn females always messing things up.
Apr 28, 2009 | Sony PlayStation Portable (PSP) Console
My psp wont charge
your battery is dead, you need a new battery its easy to find don't worry, either any game store's walmart ect..
Nov 08, 2008 | Sony PlayStation Portable (PSP) Console
Psp
How to save your dead battery: Please note using below method at your own risk, and you have been told. Take out you dead battery (PDA battery,PSP battery,Phone battery etc), wape it around by using a big piece of dry newspaper. Then put the newspaper waped battery into the freezer at below zero temperture for 4 days. After days, take the whole thing out and put in room termperture for one day. Recharge the battery and use it.
May 25, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
37 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
