Question about Apple iPod touch
Dark Screen even when i adjust the 'brightness' tab?
Hi
My Ipod touch has gone dark! i have adjusted the 'brightness' but it did not make any difference to the dim screen? any idea on what to do?
    Guru:
  • 868 Answers
Check the power settings on te unit, if it is set to default for the backlight, possible that your LCD's backlight is not powering up properly on the unit or LCD's backlight needs replacement.
Posted on Jun 04, 2010
Dim screen acer 5100-3019
Try going into power option settings and taking the brightness to the max there. Start, control panel, power options, then you should see a setting for battery and for plugin. Hope this helps.
Jun 21, 2014 | Acer Aspire 5100-3019 PC Notebook
After i tun my ipod touch on is stays on a black screen
Tweaking the brightness settings on your iPod touch saves your eyes from unnecessary strain.
Changing the brightness settings can be done quickly if you're on the go.
Adjusting the brightness of the screen can make the device brighter if you're in a dark environment or darker if you're in a bright environment.
Alternatively, you can set the device to automatically adjust to the level of brightness it's exposed to.
Press the "Home" button to return to your iPod touch's home screen.
Tap the "Settings" app.
Tap "Brightness." A scroll bar appears at the top of the screen.
Press and hold your finger against the circle on the scroll bar.
Drag your finger to the right to brighten the screen and to the left to darken the screen.
The screen's brightness will change as you move the circle.
Alternatively, tap the ON/OFF toggle to the right of Auto-Brightness to have the device automatically adjust itself based on the detected brightness level.
Tap the "Home" button just beneath the iPod touch home screen to save your changes and return to the device's home screen.
if this is not or cant fix the problem you might have restore it to factory settings
You can use iTunes to restore iPod Touch software.
Apple recommends using the latest version of iTunes to complete this process.
Follow these steps to get the latest version of iTunes and restore your iPod Touch software.
Back up your iPod Touch's data to your computer before the restore to prevent losing data.
You'll need to reinstall it after the restore process.
Connect to the Internet and install the latest version of iTunes from the Apple website.
Make sure your iPod Touch is connected to your computer.
Pick "iPod Touch" in the Source pane of the iTunes program.
Click on the Summary tab.
Choose "Check for Update."
Select "Restore" and follow the instructions to finish restoring your iPod Touch.
although it does sound like a hardware problem with the ribbon cable leads so if this fails and you are tech savy you could try to open it up and to have a look
hope this helps
Oct 17, 2012 | Audio Players & Recorders
IPOD TOUCH 8GB SCREEN WILL NOT LIGHT UP, CAN SEE IN BRIGHT LIGHT OR SUN VERY DIM.
It sounds like your back light has gone out, your best bet is to take it to an Apple genius bar. If you iPod is new enough, you ask nice enough, and if the employee is in a good mood, then they might fix it for free.
Oct 10, 2011 | Apple iPod touch
Well my ipod touch is screen wont brighten at all and i have tried to turn up the brightness and it is so dark i cant hardly see anything on the screen it just suddenly did this what can i do? other then...
Hi! I hope this will work: go in your phone settings, on the screen options, some phones come with a screen timeout for saving baterry's lifetime. Have a nice day!
Sep 01, 2011 | Apple iPod touch
My ipod touch screen has gone dark, and can barely been seen if it is then its at a certain light angle within the house.
Go into settings. You should see a buttn that says brightness. tap on that and slide the slider to maximum.
Feb 20, 2011 | Apple iPod touch
Ipod touch 2g very dim
Follow these instructions to brighten the screen.
1...Turn on I Pod
2...Slide to unlock
3...Touch "Settings"
4. ..Touch "Brightness"
5...Move the "Slider Bar button" to the Right to Brighten the Screen, Left to lower the Brightness, once you have the desired brightness on the screen you will then touch the "Settings" tag at the left corner of the Ipod to take you back to the "Settings" screen.
6.Push the button on the screen at the bottom of the player to return to the Main Screen and you are finished.
Please rate me for this Free Answer.
Dec 19, 2010 | Apple iPod touch
Hi, I have an iPhone 3G 8GB and the screen seems to be too bright. Is there a Contrast application available somewhere that I can use to cancel the effects of the brightness? Thanks, J.
The iPhone has its own brightness control. You just need to adjust it to your preferred brightness. Go to Settings> Brightness
From there, you can adjust the brightness to your preference.
For more iPhone / iPod touch tips like jailbreaking and unlocking, click here.
If you need online help about jailbreaking and unlocking, you can contact me personally at this email: sale-47hyk-1863377234@craigslist.org
Aug 06, 2010 | Apple iPhone 3G Black Smartphone
Dim screen
Dimming your screen is actually a way to save battery to extend the usage hours of your device.
To adjust the brightness of your screen, go to:
Settings > Brightness>
drag the button there to the left or to the right, depending on what you prefer.
For more iPhone / iPod touch tips, click here.
Jun 26, 2010 | Apple iPod touch
My ipod touch 2g with 3.0 firmware will not turn on
My ipod touch has gone really dark , like the brightness u cant even see anything . everything works but the screen. ive been into seetings but its nothing to do with that. what do i do
Sep 10, 2009 | Apple iPod touch
Monitor too dark....
Usually every laptop has the option of adjusting the screen brightness as you would want the screen to be pretty dim when running on battery to conserve battery life.
First thing to check would be just that.
Dec 11, 2007 | Apple Colorsync 850 Monitor
Apple iPod touch Logo
1,061 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
