Question about GE (PSS26MSRSS) Side by Side Refrigerator
The filter on our refrigerator sprung a leak and the serivceman fixed it by replacing the filter and now it is not making ice. there is no water in the ice cube tray. What has happened?
  • GE Master
  • 19,396 Answers
Hi.
Water has probably frozen inside the lines.
If possible do a complete defrost, leaving the fridge off for one day.
Before doing a defrost you should also check the water inlet connected to the back of the fridge and ensure that there is pressure and that there is no blockage (eg. kinked water line).
If you cannot move the food, you can also heat the water lines with an hair dryer. This operation is more complicate and there is risk to damage the fridge internal panels. Better doing defrost.
While the fridge is off you can also check the position of the filter by removing and putting it back. I don't think this is the problem, since the filter has been fitted by a professional.
As first thing try doing a defrost. There are more possible causes, but frozen water tubes is probably the most common occurrence.
Regards.
Ginko.
Posted on Jun 03, 2010
Why is my GE (ZFSB23D SS) side by side refrigerator leaking at the back corner, near the rear wheel where the plastic water line goes in?
If the tubing is plastic it could have cracked when you moved the tubing to install the filter. If the tubing is OK then possinly the filter isn't all the way in or is leaking.
Jul 31, 2014 | Refrigerators
Water dispenser leaks when getting water . This is Frigidare refrigerator , is it the valve on back ?
Hello Marie Baxter: If you suspect the water dispenser is leaking, make sure it is the hoses coming from the filter and not the actual filter.
Sometimes the clamps on the hoses for fridge water filters can come loose or the hose itself could crack; in which case the hose would need replacing (or tightening the clamp), and not the filter.
If you clearly find the filter is leaking, the best thing to do is make sure it is installed properly.
If it is securely in place, then you may just have a defective filter and changing it will solve the leaking.
You will need to remove the filter, which is typically located in the back of the refrigerator and inspect it to see what condition it is in.
•For instance, if it is black or looks dirty, you probably will want to replace it.
•Moreover, when there is a leak or a clog, you will notice a dramatic decrease in the output of the water dispenser tab, which is another sign there may be a leak in the water filter. If you know the water filter in your refrigerator is leaking, then you can take the water filter out and see if it has anything loose on it, but typically if it is leaking, it probably is best to replace the water filters for refrigerators.
•This is especially true if you use the filtered water from the refrigerator as your main home water filter systems.
•Moreover, if it has been awhile since you changed the filter; it can become clogged over time, which can cause it to leak.
When you are faced with having a leaking filter refrigerator water unit, it helps to think through the pros and cons of fixing the leak vs. replacing the refrigerator water filter.
Apr 19, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Ice maker
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
After replacing ice maker assembly, ice is not getting made?
http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
Ice maker is leaking water and causing the ice to freeze?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
Ice maker is noisy and not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
Refrigerator ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
Ice maker leaks water into ice bin causing a glob of ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
Amana Refrigerator leaking water from ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
Ice maker leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
Ice maker is dumping the ice cubes out before frozen solid.
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
Water overflowing ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
Ice cube is getting stuck up hard in ice maker
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
Icemaker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
Quit making ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
Water leaking into ice tray, frozen glob of ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
Not making ice, and water leaking in freezer?
http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
The ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
Ice maker not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
Ice maker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
Ice maker dispensing black pieces of plastic in the ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
Replaced Ice maker but its still not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
Ice maker leaked creating an ice block?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
Ice tray leaked?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
Ice maker stopped functioning?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
Ice maker stop working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
Ice maker failed
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
Old ice maker stopped working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
Old ice maker started leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
Ice maker not working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
Ice maker overfills and cause water to flow into ice dispenser and freezes?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
Ice maker didn't make ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
Ice maker was leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
Ice maker was leaking after it filled up with water?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
These will help.
Thanks,.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
My frigidaire side by side freezer freezes up and the filter in the refrigerator leaks water. It makes ice fine but will not freeze ice cream. theres a big clump of ice in the back which is under a cover...
the leaking water is the problem. it needs to be fixed, but till then defrost again, use a fan it speeds the process, SHUT OF WTER to ice maker. restart fridge it will work normally. now find parts needed to fix the ice maker water feed.
the leaking water overwhelms the defroster. and causes a coil freeze up, this impedes cooling and air circulation over the evaporator coils
Jun 15, 2017 | Frigidaire FRS23KF7AB Side by Side...
The water line to my ice maker in my Maytag MF12568AEB sprung a leak. I replaced the entire line, but now no water is flowing to the icemaker. The other line works fine to the water dispenser in front. Do...
No you should not need to reset anything get the water line to flow threw the water supply and raise the lever on the ice maker till water comes out if you don't get water out check to see if you left the shutoff valve off. Hope this helps. Thanks for using fix-ya.
Jan 19, 2010 | Refrigerators
Water line from house supply sprung a leak just before going into the ice maker control unit in the lower right cornor of the frig. After replacint the water line the water did not flow into the control...
What once was a leak is now no flow and no response when trying to turn on ice maker? Is the valve where the ice maker line taps into turned back on? If it's back on, first turn it off, take loose water line as close to ice maker as possible, then have someone else turn valve at tap slightly on while you watch for water flow. If no flow, start back-tracing your connections until you find the blockage. Most water connections of this type have a in-line filter. Is it clogged? If you have water pressure as close to the ice maker as you can test, next you may need to troubleshoot the ice maker it's self. Let me know?
Jan 02, 2010 | KitchenAid Superba Architect KSCS25INSS...
The place where the water filter plugs into the fridge has sprung a leak. Have not been able to use the water or ice maker.
You should be able to remove the filter and insert in its place the plug that came with the fridge. It should then run without the filter. Odds are the o-ring on the filter is nicked, or the filter is not properly inserted. It is a little tricky - if you still have the owner's manual that should clarify how the filter is inserted.
Aug 10, 2009 | LG LSC26905 Side by Side Refrigerator
Water runs from back wall of freezer and forms a build up of ice on freezer floor
You may have an ice maker that has sprung a leak in the hose. Check it and replace.
Feb 19, 2009 | LG LSC26905TT Side by Side Refrigerator
Hollow Ice- Slow Ice!!
Hollow ice is a dead give away that there is not enough water filling the trays. Check that the line isn't pinched from pushing the unit back in place, etc. Also check any filters or filter screens in the water line to the ice maker.
Jan 13, 2007 | Kenmore 55692 / 55694 Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
22 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
