Question about eMachines ET1641-02w (PT.NA60X.001) PC Desktop
Disk Read Error upon startup
Ok I startup the computer a couple seconds later "Disk read Error press Ctrl + Alt + Delete to restart" appears. I opened up the computer and everything is ok. I did some research and found out that I either need to buy another Hard Drive or change some of the settings through BIOS which didnt help at all.
  • 505 Answers
It is likely a bad hard drive. You can boot the system to a CD or DVD if you have a windows disk, this will somewhat check all other functions, and will not boot to the hard drive. You may have to go into the BIOS and switch the boot order to have the dvd drive before the hard drive. This may help troubleshoot. Some OS dvds will also have system diagnostics on them to help you troubleshoot, has to be a bad hard drive though. When you buy a new one, just see if you have the large cable (IDE 20-40 pin wire) or the small cable (SATA narrow 1/2" wire) going to the motherboard. Buy the corresponding drive and install. You may have to purchase windows discs from your manufacturer.
Posted on Jun 03, 2010
Doesnt startup,but rather displays "A disk read error occurred.Press Ctrl+Alt+Del",it does that again and again
maybe a usb device plugged? if not try in bios\boot sequence to set cdrom - hd - usbdev. then try to boot with the puppy sturdust linux cd. if it work is just the internal hd; format it and reinstall. hope it help bye
Nov 16, 2013 | Acer Aspire one D270-1375 Intel Atom N2600...
My computer says disk read error press cntrl alt then nada
In most cases, all recent versions of Windows use Ctrl+Alt+Del to bring up the Tasm Manager. You can't usually use that key combo to restart your PC.
When you did that, was any application highlighted as 'not responding?' If so, that is where you should start looking for problems.
Otherwise, try to post additional information for us here.
-a.
Mar 09, 2010 | Gateway Computers & Internet
THE COMPUTER GOES THROUGH THE STARTUP SCREEN AND THEN SAYS DISK READ ERROR PRESS CTRL ALT DEL TO RESTART AND THAT'S AS FAR AS IT GOES
This show that the disk has much bad sector and that was the extent the system could read. Replace the disk and reinstall your application slave the faulty disk to the system to see if you could recover some of your file on it.
Dec 28, 2009 | Dell Dimension E520 PC Desktop
Appear disk read error press ctrl alt del to restart what can i
for this need to restart themachine if that also doesnot fix the issue then need to reinstall the operating system.
Mar 25, 2009 | Computers & Internet
A disk read error has occured press CTRL-ALT-DELETE to restart.
check power chord or port of hard drive if u dont find any prob. pleace re insert power cord with card board packing. definetly u solve the problem.
Jan 10, 2009 | Seagate (ST3160827AS) 160 GB Hard Drive
A Disk Read Error Occured. Press CTRL+ALT+DEL to restart
Since the bios hard drive test passed , ujr hard drive is ok and mostly all ur data is ok . Only windows went corrupt (normally it doest when u turn off that way ) reinstall it dont use the recovery disks , but use a windows installation cd to re-install windows , but take care that when u install ,install on a different partition and remember to take the option leave the current partition intact without changes , so that none of ur data is disturbed.
Jul 21, 2008 | Compaq Presario R3000 Notebook
Problem with a disk read error
There are a couple of possibilities.
1. The hard drive is defective.
2. The operating system is corrupt.
The easiest way to test this is to run the restore cd that came with the computer to reload Windows.
If you get this error while running the restore cd then you will need to get a new hard drive.
Jan 03, 2008 | Computers & Internet
eMachines ET1641-02w (PT.NA60X.001) PC Desktop Logo
162 people viewed this question
Top eMachines Computers & Internet Experts
Computer Links
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
