Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Frigidaire FEX831CS Top Load Stacked Washer won't fill with water
    President:
  • 1,430 Answers
First you should remove the hoses and clean the screens in the ends of the hose, some hoses have screens in both ends. While the hoses are removed look inside the water inlet valve there should be a screen in there also remove and clean the screen out. Some screens will not be removable so you will need to clean in place or remove the water inlet valve. If all is clear you will need to check the solenoids on the water inlet valve for power.If the solenoid has power when put in a fill cycle and no water eneters your washer you will need to replace the water inlet valve. Most water inlet valves must be replaced as a unit, so if one solenoid fails you replace the hole valve assembly. These are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/topwaterinletvideo.html that will walk you thru the testing procedure. It may be a different model but the testing will be the same. If you need help disassembling there are also videos of disassembling most styles. You can also enter your model # for diagrams and illustrations of your specific model. Not all models will be available. All parts come with installation instructions.
Posted on Jun 03, 2010
Frigidaire FEX831CS Top Load Stacked Washer / Dryer dryer won't start
Hello - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and start normal cycle. If this proves to be ineffective, then contact a professional to move forward accurately. Possible causes could be a faulty power cord or house wiring, defective control board, thermal limiter or door switch.
Oct 22, 2012 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire Fex831cs Top Load Stacked Washer won't agitate
I worked on one last week which was completely dead. Some wires were cut. Took a few pics: Laundry Center repair
Service manual
Jun 21, 2012 | Washing Machines
Washer won't fill with water but cycles normally
Does the washer have its own water source?
Check to make sure the water is turned on, and that the hose is free of kinks.
Mar 03, 2011 | Frigidaire FEX831CS Top Load Stacked...
Won't fill with water and goes right to wash cycle
Chech the pressure lelvel switch and hose that is connect to the pressure switch and tub
Mar 25, 2010 | Frigidaire FEX831CS Top Load Stacked...
Water won't work but dryer does
Mine did the same thing and it ended up being an overloaded older breaker in the electric box. It would allow the dryer to work, but the washer was too much for it to operate. Had the breaker replaced with a new one and it works fine. Hope this helps!
Jun 14, 2008 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
738 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
