Question about Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A200 - black screen at startup
At startup I get 3 beeps (one long and 2 short) and then a blank screen. After 20 or 30 times of rebooting it reboots. I've tried removing the battery and booting with just the power cord, removing the RAM and booting with just one or the other to no avail. I haven't been able to find a solution online to this problem and it is preventing me from shutting down or rebooting to upgrade programs. Anyone have any ideas?
  • mabadvisor Jun 03, 2010
    I have not checked the video settings in my bios or rest the bios defaults. Any guidance on how to do that would be helpful. Thanks for you quick response!
    Thanks for your quick response - I have not check the video settings or reset the bios. Any guidance on this would be helpful. Thanks!
    Scholar:
  • 151 Answers
1 long and 2 short beeps generally indicates an error with the display adaptor.
This may require either checking the video settings in your bios (but sounds like you already have), reseting BIOS defalts (again, sounds like you have done this) or may require a new motherboard.
Posted on Jun 03, 2010
  • gclosen Jun 16, 2010
    during startup when you have the TOSHIBA splash screen, there will be directions on how to get into your BIOS setup...either the DEL key or F2 or ESC.
    Once you are in the bios you should be able to find the "Load bios defaults" or "load optimal settings" on the last page of the BIOS screen. select this, then exit and save your changes.
    I hope this helps
  • 484 Answers
  1. try to back up the files on an external drive
  2. re install the windows
  3. and try to turn it on to see if there will be any improvements
  4. avoid loading the laptop with too many files,
  5. in case of storing files, try to use an external hard disc.
if it does the same, then it is a hardware problem.
  1. try to test the components (RAM, battery, mother board etc) in another similar laptop and see what happens.
if the problem persists, then you have to replace the board of the laptop.
take care.
Toshiba laptop beeps 3 times on startup
hi tom2590
usually 3 short beeps is an indication that you have a bad memory module. try reseating the memory module and see if the laptop would run. also if you have 2 ram modules try removing the other one to test. hope this helps
let me know
janc30
Feb 11, 2011 | Toshiba Satellite A75-S229 Notebook
Toshiba satellite A200 - press power to turn on the machine and get blank screen and 3 beeps then nothing. Computer was left in sleep state for approximately 2 hours and now refuses to wake or reboot...
HI
Try to unplug the power supply and take the battery out. so it means there is no power going to the laptop. now press and hold the power button down for approximately 1 minute.
After that put the battery in and plug the adapter back.
Try to turn the laptop on most probably it will come on
If it still does the same thing contact ur laptop manufacturer
Jul 18, 2010 | Toshiba Satellite A200-16J01D Notebook
Toshiba Satellite Pro A200 BIOS Password Request
for removing the password,
you have to open the memory cover and remove the two RAM s,
after that remove a black or whit plastic film depending on your model, you will loacte for B500 marqued ( XXX ) or J1 you have at least short
the two point with a flat screwdriver and put the upper memory and power on the laptop will holding the screew driver till you see the toshiba screen, if it doen't work just try again. it works 100%
Jun 15, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Laptop won't reboot
are you trying to put win 10 on as it can do this some time, can take upto 10 15 min to load, when the like is flashing its dos, when the screen is black its windows it takes some time for windows to find a driver and load it so the screen comes up. i've had this on a200's before. if you keep rebooting you will need to wipe the hard drive and start again. this also does this on win 7 and 8. win xp it does not do this as its full dos setup .
Jun 30, 2017 | Toshiba Satellite Pro A200-EZ2204X...
I have a Toshiba A200 and the screen is completely
Sounds like the screen is faulty I would check the screen connection to make sure its not lose but I would say the screen is almost gone.
You may need to replace it.
Feb 25, 2010 | Toshiba Satellite A200-19501F Notebook
My toshiba A200 screen occasionally turns black and music also stops. When i try manually restarting my laptop, sometimes it works but most of the time it doesnt boot at all. Sometimes it doesnt even go...
This sounds like a hard drive is, or has failed. Either that or the RAM (memory has gone bad)
Did you let the laptop overheat? Was it left on for a long time? Or is this just an old machine ?
I would replace the hard drive, and reload the operating system, that is if you really want to keep the laptop. If that solves it great! Also, did you notice if there are any "beep" noises, or error messages when it acts up? Often times, you can go on the internet and find out what the messages mean.
Jun 17, 2009 | Toshiba Satellite A200-0ET00X Notebook
Toshiba A200 black screen after bios upgrade failled
Download the bios update, and try the diskette based BIOS update installation options.
Dec 09, 2008 | Toshiba Satellite A135-S2276 Notebook
Screen not coming on
Recover the windows to earlier date
i had same problem but it is fixed now
does it help!!!!!!!!
Jun 29, 2008 | Toshiba Satellite A200-0ET00X Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
1,537 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
