Connecting Virginmedia TV settop box to PC using Philips TV capture card. Result - sound and picture BUT black & white!!
  • 813 Answers
Hi friend
can u install driver proper if have install paroper then tune it NTSC OR PAL system if problem occers then romove your card driver & reinstall it
& thnx using fixya
Posted on Apr 09, 2008
  • 385 Answers
Maybe you need to check the software settings for the tv capture card. It might be on a black/white setting instead of multicolor.
Thanks,
Lolita
  • 472 Answers
You are either running NTSC into a Pal system or the other way around. Check the setup menu on the Virginmedia box to make sure what it's running, then make sure the TV card is running in the same format.
Hope that helps =)
I HAVE CONNECTED THE TUNER TO PCI SLOT~ INSTALLED DRIVER & TVR2.5 SW ~ IT HAS SCANNED THE CHANNELS & TOTAL 65 CHANNELS ARE LISTED~ UNABLE TO GET ANY PICTURE & SOUND IRRESPECTIVE OF WHICHEVER...
Hello, I suppose you used the factory software suite. For my Pinnacle card it didn't work. Besides the obvious remove/uninstall reboot and try again method I recommend you try a third party application such as Honestech TV Plus Gold. It has a free trial so it is a good way to check whether it is a software problem or other installation issue.
Aug 08, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
Plugging red to red, white to white, and yellow to SPDIF (black) and got no picture with sound. Plugging red to red, white to white, and yellow to green and got black and white picture with sound. How...
First you need a component cable to solve your problem.Since you have not mentioned what device you are connecting to your TV, I''ll assume its a DVD player or a settop box.There is a Red and White audio sockets + Red / Green / Blue component video socket. Just make sure you connect the corresponding two sets of jacks at both end of your TV & DVD player and everything will work. bobhifi_21.jpg
Mar 27, 2011 | Philips Televison & Video
I have a frontech pci tv tuner card with philips chipset SAA7130 installed on pc gives images but no sound?
Hello
The package contains an audio cable, connect the cable audio out from card to audio in of computer and connect the speakers at the same place where it is,
or you can directly get audio from tv card by connecting speakers to audio out connectors.
Hope this helps, if so do rate the solution
good luck
Dec 30, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
How do i connect my ps2 to my pc?
The yellow plug should plug into the the yellow hole on the capture card (should be second hole from bottom, next to green hole).
You will need to get a Y audio adapter with two RCA plugs going to one mini stereo plug to connect the red and white plugs to the green hole to capture sound.
Jun 06, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
Picture black & white menu color #26mf231d/37
I have the same problem too. Need a fix. This tv isnt that old and is not used that much. does not seem to be the cables or cable box. the menu has color to it but the channel picture is in black and white, flickers a bit, and seems to be in a very large pixle form. it this able to be fixed? Please Help.
Nov 10, 2009 | Philips Magnavox 27MS343S 27" TV
Connecting hd cable box to philips 60 rear projection
So, You have Five cable leads, The rgb get plugged into there corresponding colors and the other two are your Red and White Audio Input ------Correct? You do not use the in4, that is for a pc with horiz and vert sync. You use input 1 rgb and plug the red and white into the audio input.....your done!
Jun 06, 2009 | Philips 60PW9363 60" Rear Projection...
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card problems
Have you checked the installation? - most PCI capture cards use the audio card of the PC for sound. A jumper cord is needed to come out the capture card and into the audio line-in jack. Green jack on the capture card is OUT, and the Blue jack on the sound card is Line IN.
Jun 17, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
MY SAA7130 TV TUNER CARD IS NOT OUTPUT NORMAL CA LOUR IT SO ONLY BLACK AND WHITE CA LOUR ONLY PLZ SOLVE MY PRB.
Dec 02, 2007 | Televison & Video
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
