Question about GE Refrigerators
GE PRofile side by side Model psc23sgpass - the
GE PRofile side by side Model psc23sga - the temperature in the freezer is at 39 and in the refrig it is 52 - it is not cooling. I have adjusted the temp controls and it still is not getting cooler
  • eiduff Jun 03, 2010
    I don't understand what the last expert was trying to tell me - refill the gas on the compressor?????
  • RobC
    RobC Oct 24, 2013
    Our water dispenser leaks. The technician says that the heater inside the door panel that is used to prevent frost build-up on the condensor is bad and the only solution is to replace the freezer door. Does anyone have a better solution. Replace doors are $400-$500
  • GE Master
  • 1,606 Answers
You do not have a gas leak . Only inexperienced persons calling themselves technicians , use that as a " scapegoat " . Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temp is reached .
Posted on Jun 04, 2010
  • GE Master
  • 19,396 Answers
Hi.
The most common cause for this problem is the defrost system. The function of the defrost system, located at the back of the freezer firewall, is to prevent condenser coils at the back of the fridge from cooling down and icing up. When the defrost system is defective you get poor cooling.
You can test if the problem is the defrost system by leaving the unit disconnected or off for 24 or 48 hours.
If problem was the defrost system, then the problem will disappear after full defrost, to come back in a couple of weeks.
Other problems that can cause insufficient cooling are compressor problems, refrigerant leaks, and depending on the model, electronic control faults.
Start doing a defrost for 12 or 24 hours.
Regards.
Ginko.
Posted on Jun 03, 2010
    do you know the approximate cost for fixing the condensor freon? Can someone refill the freon?
  • Ginko
    Ginko Jun 03, 2010
    To start, modern refrigerators do not use freon.
    The cost to fix a leak and refill gas starts at about $120.
    You do not know if you have a refrigerant gas leak. Follow the indications in my previous comment.
    Regards.
    Ginko.
    Genius:
  • 1,417 Answers
what this indicate is that the compressor of your need to be reggae with some gas because the level of gas is now low then it has bee difficult for the condenser to frieze up the refrigerator
what you need to do for fixing up your fridge problem is to re feel the compressor with refrigerator gas has it was explain above the compressor is like a black at the back of the fridge while the condenser is the thin pipe connected to the compressor which transfer gas to the inner position for cooling and frizzing
please note this, before any of this function is carry out as work all form of power supply most be put OFF .
thank you and thanks for using fixya.
  • Oloyede Monsuru Jun 03, 2010
    hello
    eiduff , the explanation giving is you is solution to the problem of you
    freezer whenever the temperature fall or move higher then what is
    expected is that gas will need to be refill so as function on what is
    expected of it
    thank and good luck.
    hello,
    what i mean is that you need to refill the compressor with gas
    so that the fridge can work fine again
    the compressor is like a black pot at the back of the fridge if you
    can carry out this advice then the problem is solve .
    thank you.
GE frig not cooling, both refrig and freezer. started with ice/water dispenser not working.
WR55X10942 Main Control Board This sounds like motherboard failure. I am not sure what your model number is but that will be important should you have someone to help repair your refrigerator. These problems are common on the Artica Profile Models. I will be here to help you repair if you should choose, Thanks Sea Breeze
Apr 24, 2013 | GE Refrigerators
GE pss25ngnacc____refrigrato is to cold can't control tem
start by putting freezer control on half way on the numers. lets say it goes to ten set on five, do the same on refrig side . let run for 24 hrs. so it can stabalize. if it is ok in freezer and things are frozen and too cold in fridge side turn the refrig side to one smaller number. check again in 24 hrs. don't keep opening the door so that it can stabalize. if that doesnt work then it could be the cold control not senseing the temp of the refrig.
May 26, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE SIDE BY SIDE MODEL #GSH22JFRE CC FREEZER COIL FREEZING AND REFRIG NOT COOLING. DEFROST MANUALLY AND REFRIG COOLS FOR A COUPLE DAYS, THEN FREEZER COILS FREEZE AGAIN
We have a GE side by side that was only 4 years old before it starting giving us problems-coiling freezing over. The warranty period was only one year on all parts, including the compressor. Through our research we learned that profile appliances have or did have a better warranty. I believe it is 5 years on all or certain components. Either way it may be worth contacting GE customer service to help you with the issue and determine if repairs and parts for your appliance are still covered under warranty. They were very helpful in our case and ultimately discounted the parts I ordered and replaced myself. Replaced the the temperature sensors on the freezer side, the defroster thermostat and defroster heater before finally breaking down and replacing the control board. The control board was the problem. It was very easy to replace. While working through the issue, we would defrost the coils located on the inside of the freezer side with a hair dryer. It would get us by until the parts came in or they frosted over again and prevented air from circulating over them, thus causing the freezer not to cool. Good luck. Hope this helps you.
Nov 23, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
I have a GE profile side x side refrig. The
Your owners manual , will tell you the minimum clearences for the refrig . If I have 2 refrig's on my test line , less than 2 " apart , both will emit moisture on the sides , depending on the weather . There has to be air flow on the sides and rear . Sorry this doesn't answer your question directly , but there is no product that can be installed , to stop this problem with the refrig . However , you may , pull the refrig out , and treat the faceing wood , with a waterproof paint or sealant . It sounds like this part of the cabinet , will not be seen . Plastic will not work , moisture will just go thru it . Yes , treating the faceing wood sounds like the most logical solution .
Oct 23, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE PROFILE REFRIGERATOR MOTHER BOARD PROBLEMS i REPLACED THE MOTHERBOARD AND IT STILL DOSEN'T KEEP THE PROPER TEMPERATURE. It varies from 36 to 45 degrees.
Go into the diagnostic mode on your touch display .
1) . Press any button on the display 1 time except the temp adjust buttons.
2) Press the temp up and down on both the freezer AND refrig (all 4 at the same time)
3) when 0's show , release the buttons and press any button except for the temp adjust buttons .
4) NOW , fress the temp adjust buttons until the freezer side displays 0 and the refrig side displays 7 . 0 and 7 is for the thermistors test .
5) After 0 and 7 display , press any button again except temp adjust , and this will start the thermistor check .
6) You will have 7 thermistor tests , indicated on the refrig display , starting at 1 , then 2 then .......
7) The feezer display will tell for the corresponding thermistor , indicated by the refrig display , if the thermistor p = pass , s = short , b = bad (replace board)
After determining if or which thermistor is bad , then adjust the display to 1 on freezer display and 6 on the refrig display . This ends the testing procedure and resets the refrig back to normal .
Sep 26, 2009 | GE Profile PFCS1NJWSS Stainless Steel...
Cannot control temp on refrigerator side
thermostat problem replace that if you know how to do that or call a technician who will help you
Sep 12, 2009 | GE Profile PFS22 33" Artica French Door...
Not cold
if there is ice on the back panel of your freezer your defrost is not working. Your need a new heater coil. or it can be the timer.
hope i was helpfull to you.
Aug 12, 2009 | GE GSH25JFR Side by Side Refrigerator
Temperature of Refrig and Freezer too warm
Sounds like your fridge may be short of refrigerant.
Mar 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
618 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
