Question about Canon CLC 1120 Color Copier
E072 - 0002
I've got an error code as E072 0002.
It's a Canon CLC 1150.
Thank you in advance.
Max
  • cgibrail Apr 12, 2008
    hI,
    I´ve got the same error as Kaifr´s. My nachine is also the same. I have changed its motor but didn´t fix the problem. help!!
    is it possible to send the answer to my email? cgibrail@yahoo.com
    Thanks a lot in advance
  • Anonymous Sep 06, 2008
    CHECK BRUSH MOTOR AND BRUSH IN OTHER MACHINE
  • 4 Answers
Most of the time if you replace the transport cleaning unit it fixes the fault. on one machine i had a break in the wire lume that caused the problem. also make sure you don't have a piece of paper jammed in the unit.
Posted on May 07, 2008
Service manual
Code error E 020, 0173
Jul 09, 2013 | Canon CLC 1180 Copier
CLC 1150 Color Coiper E020 0142 What does this
Toner feed error, possibly clogged up in a feed tube, or in between hopper and developer.
Will most likely need a service technician to fix.
Dec 04, 2009 | Canon CLC 1150 Color Copier
CLC 1180 gives the error code E804 000B and instructs me to turn the unit off and on again. Once this step is completed, it reoccurs.
E804 0006 The laser scanner motor
cooling fan (FM4) has
stopped to rotate in error.
There is no 000B in the manual....so I assumed it was a six.
The sub codes possible are 0001, 0002, 0003, 0004, 0005, 0006, 0007 and 0008. They all pertain to cooling fan failures.
Oct 19, 2009 | Canon CLC 1150 Color Copier
E0000 0132 error on Canon CLC 1150
this is the fixing error indication reset it * 2 & 8 simultaneously * Copier>Function> Clear>Err>OK .Restart the Machine
Jun 20, 2009 | Canon CLC 1150 Color Copier
Canon clc 1150
9 times out of ten that means you need a new drum when it does print does it look ok?? if yes then its definatly the drum it measures the voltage on the drum when its worn this code happens sorry
Jan 16, 2009 | Canon CLC 1150 Color Copier
E005 0100 Error
asfter clearing the error code turn the machine off then on again, if that dosen work remove the web then clear cut off turn on
Nov 25, 2008 | Canon CLC 1150 Color Copier
Canon CLC 1150 - E804
it may be the fuse board or the relay near the fuse board that is arcing
May 19, 2008 | Canon CLC 1150 Color Copier
Clc 1150 error 350
Normally only the canon service center will tel you what the error codes means. Suggest you call them .
May 18, 2007 | Canon CLC 1150 Color Copier
Hi again
sir, i have canon 1150 machine. i want this usear guide and error code guide. my machine is jointed with fairy.if u have this guide please send me thank u manish email-mahavir_mds@yahoo.com
Apr 15, 2007 | Canon CLC 1150 Color Copier
Canon CLC 1120 Color Copier Logo
582 people viewed this question
old marine
old marine
