Question about Datamax I-4208 Thermal Label Printer
Getting end of forms on spool file be sent to Datamax 4208 .. labels are 2 across .. 1 1/2 by 4 inches.. how to set attributes for spool file.. overflow line incorrect on message .. ??
  • kschuman39 Jun 04, 2010
    I am getting a spool file message : End of forms ... The program that is writing the print command lines to the spool file is being called from an IBM AS400 to a Datamax 4208 thermal label printer. The RPGLE program is using IPL syntax ... Intermec Printer Language. The spool file attributes are being overridden in the program using the Qcmdexc call..
    I am setting the page size to a page length of 8 and page width of 40 with an overflow of 10 .
    I am getting an incorrect overflow line message on the spool file being sent to the printer.
    eval Cmdfld='OVRPRTF FILE(VS335R) TOFILE(VS335)
    ' PAGESIZE(8 40) OVRFLW(10) OUTQ(PRT22)
    CALL 'QCMDEXC'
    The labels are 1 1.2 by 4 inches with 2 labels across.. The goal is to print twice ,
    1. item desc 1
    2. item desc 2
    3. item #
    4 . Lot #
    5. Barcode including item# /Lot #
  • 503 Answers
Use a CL to override your printer file attributes, eg,
OVRPRTF FILE(PRINTER) PAGESIZE(80 198). This sets the page length to 80 lines and a width of 198. This forces concise setting for your spooled output. You can also place output to hold in the CL (SPOOL (*NO, HOLD(*YES), SAVE(*YES)). THis means that u will hold the spool file and save a copy of it after printing. In this case, u are not req'd to print it, but saving a copy will allow u to also display the attributes.
To display the attributes for your spooled file, search for the copy of your saved spool file, use option = 8 (attributes), page down until u come to this page (page down abt 3 x)
Page range to print:
Starting page . . . . . . . . . . . : 1
Ending page . . . . . . . . . . . . : *END
Record length . . . . . . . . . . . . : 80
Page size:
Length . . . . . . . . . . . . . . . : 66
Width . . . . . . . . . . . . . . . : 132
Measurement method . . . . . . . . . : *ROWCOL
Lines per inch . . . . . . . . . . . . : 6
Characters per inch . . . . . . . . . : 10
Overflow line number . . . . . . . . . : 60
Fold records . . . . . . . . . . . . . : *NO
Control character . . . . . . . . . . : *NONE
The Page Size panel is the one u are interested in. In this case, the length of the spooled file = 60 lines and the width is 132 chars.
If you are just a user and do not code CL, then u can always do a change spool file (select option =2 (Change) against a specified spooled file, and save a copy before the fax software gets to it. Then use the method above to display the attributes. If u are coding the program, re-design to run your ILE/RPG program from the CL call. Then include the OVRPRTF command into the CL program
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Jun 04, 2010
    yes i have been changing the spool file size. I get truncated line errors. When they are corrected I get end of forms. My problem is finding the correct size.. for a 1 1/1 x 4 in. label... I fix the truncation and get end of forms. Fix end of forms and get truncation.. thanks any thoughts on the pricise sizing for those specifc labels. ?
  • 4,281 Answers
For that press windows key + r so you can see run type in run "cmd" without "" then press enter.Then you can see command prompt.
Type in prompt "net start spooler" then press enter.Then spooler service will start.
You can also enable print spooler in control panel->printer and faxes Right click on printer icon click on property then click on advanced then enable print spool.
Also go to run type run "services.msc" press enter then you can see services list select print spooler and right click on it then stop it and restart .
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Jun 03, 2010
  • kschuman39 Jun 03, 2010
    The program that is writing the print command lines to the spool file is being called from an IBM AS400. The RPGLE program is using IPL syntax ... Intermec Printer Language. The spool file attributes are being overridden in the program using the Qcmdexc call..
    CALL 'QCMDEXC'
    1. item desc 1
    2. item desc 2
    3. item #
    4 . Lot #
    5. Barcode including item# /Lot # SEE PICTURE BELOW
Datamax M 4208 Printer - Barcode is missing when we print the label and we also get 10 extra blank labels with it. Please help me with a solution
Sometimes it's simply the Internet Browser settings. Go to File, then Page Setup and change the margins to 0.1 and all footers and headers to Blank or Empty.
Feb 28, 2013 | Datamax M-4208 Thermal Label Printer
Datamax I-4208 has different position than i-4308 or prodigy max
On the I-4208s, press Menu button on front of printer. Go to Print Control. Go to Custom Adjustments. Go to Row Adjust. Change Row setting as needed. Ok to go negative.
Feb 17, 2012 | Datamax I-4208 Thermal Label Printer
I have got a datamax m class mark II and i have got a fault top of form and i can not print anything or i can not connect to printer from my computer. i have all drivers on and i think all is fine but i...
1)PLACE THE SENSOR IN TO THE LABEL GAP PROPERLY 2)CHECK THE SENSOR TYPE IN PRINTER(menu->media settings->sensor type) 3)PERFORM A MEDIA AUTO CALIBRATION(press and hold feed on control panel) 4)SET FACTORY DEFAULT SETTINGS
Apr 15, 2011 | Datamax M-4208 Thermal Label Printer
The printer is datamax I 4208 give me an error top of form fault
Try moving the sliding green media guide out from the wall about 1/4 to 1/2 inch, until the white line is under the label path. This green piece holds the label sensor, which needs to be under the labels so it can sense the gap between labels (or the black mark on the bottom side of the backing, if there is no gap). Also, on the printer menu you must choose whether your stock has a gap (aka web) or black mark (aka reflective).
Oct 12, 2010 | Datamax I-4208 Thermal Label Printer
Datamax i -4208 printer
Any Thermal Transfer or Direct Thermal label on a 3" i.d. roll with maximum o.d. of 8" and label width between 1" - 4". Thermal transfer labels require appropriate ribbon.
Nov 24, 2009 | Datamax I-4208 Thermal Label Printer
Datamax I-4208 ribbon loading
Follow the arrow symbols stamped on the ribbon spool assy
Sep 24, 2009 | Datamax DMX-I-4212 Label Printer
Zebra 140xiIIIPlus w/ attached cutter, cutter will not cut labels
For the cutter to work it is necessary to instruct the printer to "Use the cutter" This setting is usually accessible in the printer driver. Your label program interacts with the printer driver. Ensure that the cutter option is selected in the printer driver.
Apr 02, 2009 | Zebra 140XiIIIPlus Direct Thermal-Thermal...
Datamax I 4208 prints slow when set to landscape
try using a seagull sceintific driver.
also if you are sending graphics (barcode) instead of an actual barcode decoded font, the printer will process as a graphic.
If serial, speed up to max, if parallel it should print quite fast
Jan 21, 2009 | Datamax M-4208 Thermal Label Printer
DatamaxI class 4208 top of form fault
The printer must be calibrated or the type of sensor is wrong. Verify that the sensor type is correct for your label (gap or black mark) and you can calibrate it by pressing the FEED key for about 5 seconds approximately.
Jun 22, 2008 | Datamax M-Class 4208 Thermal Label Printer
Datamax problem
You probably need to adjust the leveling cam if you have not done so already. This is the green thumbscrew near the print mechanism.
Dec 18, 2007 | Datamax M-4208 Thermal Label Printer
Datamax I-4208 Thermal Label Printer Logo
134 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Joseph Mueller
Joseph Mueller
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
