Question about GE WPGT9360EPL Top Load Washer
Washer does not spin or agitate cant find a fuse
  • GE Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing Machinewasher does not spin or agitate cant find a fuse - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 05, 2010
Our whirlpool wtw5100vqo agitator doesn't work I already replaced the agitator dogs
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Apr 03, 2015 | Whirlpool Washing Machines
Washer won't agitate or spin
Oct 12, 2014 | Whirlpool Washing Machines
Whirlpool washer fills sometimes and won't agitate or spin or drain what should i do
Jul 24, 2014 | Whirlpool Washing Machines
My ge washer will not spin or agitate
check the continuity of the magnetic switch under the top cover and the plug connection to the switch,they get bad and dont make connection then it cant agitate or spin
Apr 18, 2013 | GE WJSR2070B Top Load Washer
Washer won't spin or agitate
You need to check the fuse link in the console. These are known to burn out quite often. Here is a link to the part.
Oct 19, 2012 | Hotpoint VWSR4160GWW Top Load Washer
Agitator does not rotate during washing , but rotates during spin dry
Is the agitator a back and forth or does it only agitate in one direction. While it is spinning if the agitation mechanism is broken the agitator will spin with the speed of the bowl and just freewheel. you need to look to see if it is a belt driven agitator, if it is buy a belt for your model number of your washer and find someone handy to fit it if you cant yourself. If it is mechanical agitator chances of fixing it yourself are slim. Weigh up the cost of parts and labor as well as call out fee for the repair man and check if its easier and cheaper to just get a new washer.
Apr 11, 2011 | Washing Machines
I have an A211 washer and it will not agitate. it fills and i can get it to spin but i cant get the middle piece to work. also, the agitator will not move by hand, it is locked.
Maytags will always spin because the whole trans turns in the spin cycle so the only thing doing any work is the motor,but when they won't agitate it is a bad transmission,if you have the old helical drive it runs $500 part # w10172458 if you have the orbital drive it runs $225 part # 22002127 they were good washers but that is a lot of money.
Sep 21, 2009 | Washing Machines
Maytag washer won't fill or agitate; only spins on cycle
sounds like you have a blown fuse. I dont have a schematic so I dont kno where you have to look to find it
Dec 30, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Kenmore 90 series washer
most likely the agitator dogs are bad. if the agitator engages clockwise and free spins counter clockwise they are good, if it slips they are bad. remove the bolt in the center of the agitator, take off cap or dispenser and remove the inner cap first. pull out the agitator, put on the floor, stand on the base of the agitator and pull up on the upper part to separate, take out the dog holder and replace dogs. Most appliance repair shops should have part on hand for about 5-6 dollars. part number 80040-fsp.
Jan 14, 2008 | Kenmore 24032\24036 Top Load Washer
GE WPGT9360EPL Top Load Washer Logo
96 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
