Proview 700P lcd monitor problem
Proview 700P tft/lcd monitor - will only show wallpaper display not any icons or task bar or the mouse arrow after loading - am trying to use it with a Dell latitude laptop as an external monitor - works ok if booted in 'safe' mode but not in normal mode.the XP o/s appears to see it ok and identifies it as plug and play 2nd monitor - any idea's
  • 472 Answers
Your monitor has been enabled as an extended monitor, not a clone.
Easy way to see is open a window, grab it and drag it to the other monitor (drag it right, not left). Just remember even if you have the external monitor on your left side, it is really on the right side according to the computer.
Check the display properties for a clone option if you want both to show the same thing.
Hope that helps a little.
Posted on Apr 09, 2008
How can i download driver for proview 700P?
you can download it from a website called driver guide. I have downloaded it and confirmed no viruses and to be the proper driver. Click here for the proview 700p driver
if you need further assistance please let me know, Thanks-Midwest-tek
Aug 28, 2010 | Proview PL913B 19" Flat Panel LCD Monitor
My proview 700p has lines and picture jumps can anybody help me please
Look at the power supply first, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 24, 2009 | Proview PL913B 19" Flat Panel LCD Monitor
How to control the brightness of Dell TFT monitor
That's the buttonsd on the monitor, not the PC.
Press the [menu] button on th emonitor.
The screen will show the labels of the buttons now.
press the "arrow" to position to the brightness setting (the "sun" icon)
press the minus [-] button to dim
Press [Menu] to save & exit the OSD (on screen Display)
Sep 30, 2009 | Dell E193FPp 19" TFT LCD Flat Panel...
Task bar displays
Just right click the task bar and click properties and then click customize , then click restore default Over!!!!
Aug 22, 2009 | Microsoft Windows XP Professional SP2 Full...
My monitor does not work right. it says vga not support.. its a proview 17" flatscreen..active matrix tft lcd
I suspect your Computers Display settings need adjustments and or a Driver from Proview installed...therefor if you can get on the net, I would look at FAQ's on Proviews Website, i.e:
http://www.proview.net/Support/FAQ_Question.aspx?pi=2026
hope that helps,
Bastian
Jun 02, 2009 | Proview PL713S 17" Flat Panel LCD Monitor
How to use this Proview LCD Monitor 17" 700P AS A TV Screen
No. The newer LCDs can do both. But they are a TV to start with the option to hook up a Desktop.
Feb 08, 2009 | Proview PL713S 17" Flat Panel LCD Monitor
Monitor 700 P proview TFT problem
Try changing out all of the capacitors on the power/inverter board first.
You probably do not have to change the large main one, Just the other ones.
It sounds like you have voltage but your amperage is not there. the 11.7 should probably be closer to 12.
Ebays
bammbammfran
Oct 28, 2008 | Proview PT 15.1" LCD Monitor
Preview 700 P
you should change al lthe caps in the PSU.. you can get them all from Maplins for a few pounds.
best get 105 centigrade ones
Oct 25, 2008 | Proview XL370B (Black) 17 in. Flat Panel...
Need help: ProView 700P Silver LCD Monitor
You do NOT need a driver. Your monitor is broken. The high voltage power supply that provides power to light the CCFL cold cathode fluorescent lights is broken. The most common problem is that the 470uF 25V capacitors on the power supply circuit board are bad. Bad Caps have a swollen and sometimes leaky top. There are 6 capacitors that cost about 50 cents apiece from www.partsexpress.com . Buy high temperature replacement capacitors rated at 105C. If you can't de-solder and resolder have some 14 year old kid do it for you.
Feb 26, 2008 | Computers & Internet
Computers & Internet Logo
126 people viewed this question
David Payne
David Payne
