Question about Mitsubishi WD-65731 65" HDTV
Theres no picture
When i turn on the tv theres no picture but there is sound and it will be on for about a min. or two then it turns off and a red light turns on
I have the same tv as you with the same problem. I'm sorry I have no solution for you but I can tell you that it will keep happening over and over and over again. We have had ours for just about 3 years now and have had to replace the lamp 6 times (it does the same thing to us, sound but no picture and then turns itself off) you can try to push the system reset button on the front panel of your tv but most likely that won't work. We have also replaced the fan and the light fixture twice. Best Buy (where we bought the tv) has now spent double what we originally spent on it just to "fix" it. I would recommend fixing the bulb and selling it as quick as you can unless you want to spend over $1000 a year on maintenance. We know 2 other people with the same tv just a smaller size and they have both had the same problems we are having. This model obviously has a major problem but neither Mitsubishi or Best Buy want to do anything about it other than temporarily fix it until my warranty wares out. Get out while you can is my advice to you.
Posted on Jul 03, 2010
  • alex_saab99 Nov 26, 2010
    put fan close to the tv and keep the tv altel cooler the problem will resolve is the high temp that kill the bulb life
  • 505 Answers
Likely a bad lamp. It is customer replaceable. Instructions are in your manual. Pull out the lamp and check to see if its shattered or bulged. If so, order a new one. Mits TVs do poorly with generic lamps, so an OEM lamp is recommended.
Posted on Jun 03, 2010
  • thielectronick
    thielectronick Jul 04, 2010
    If you have repeat lamp failures, make sure that the lamp is getting adequate air flow, some of them have a screen that will clog up on the lamp housing, others have an actual filter that should be cleaned yearly and/or when you change the lamp. Also, mitsubishi's do seem to have more failure than other brands, and they are really bad when you use generic (not same brand as original - philips, osram, etc - look on the backside of actual bulb) lamps... get the OEM ones for a longer fix, but yeah, they do fail a lot. I've seen some generics only last like 4 months and then they wont fire anymore. It could be a bad ballast over firing the lamp, but thats really really hard to check.. If it were my tv, I would try to "mod" it to get more airflow and keep that lamp really cool.. upgrade the fans, add more fans, or more airflow openings. Best of luck
I just had my bulb blow I am a 52 year young woman and was able to remove the bulb and order another one. No issues if it gives me the same amount of time the last one did I can't complain. Air flow is good just has lots of hours on it. My suggestion is to blow it out before replacing the bulb to get all the dust off the fan and make sure your fan is working properly if not replace it's not that hard.
Posted on Aug 29, 2010
4 Suggested Answers
milmar
  • 50 Answers
SOURCE: Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Posted on Aug 11, 2008
  • 301 Answers
SOURCE: it started 3 days ago
REPLACE THE LAMP IT IS LOCATED IN THE BACK OF THE TV THERE ARE INSTRUCTIONS IN THE OWNERS MANUAL FOR REPLACEMENT IT IS CONSIDERED CUSTOMER REPLACEABLE ITEM.
PART NUMBER 915B403001 Lamp (180W)
Posted on Dec 17, 2010
SOURCE: WD-52631 Red Light-No Picture, still have Sound
I also unplugged from the wall, and did the reset procedure. That worked a few times and then it didn't work anymore. Thanks for the help, just wanted to warn it may only work temporarily.
Posted on Oct 07, 2013
The tv made poping sound & it lost the picture but the sound was ok, their is buzzing sound coming from inside the tv, after about a min. the set turn off & red light stays on. reset tv, same...
This model is prone to a lot of problems to the point where a year or so ago they offered a chassis replacement on an exchange basis.
I would with rear cover removed try to localize first where the sound or buzz is coming from: The ballast? the Light engine? The power supply?
I can help but as I said this model has a LOT of chronic problems.
Steve
Nov 01, 2011 | Mitsubishi WD-52525 52" Rear Projection...
It started 3 days ago the picture started getting darker and darker everyday then last night after turning the tv off which was off for several hours I turned it back on and a few min later there was a...
Dec 16, 2010 | Mitsubishi WD-65736 Television
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
Dec 25, 2009 | Televison & Video
Green power light comes on for a split second, then red.
The power supply (AC adapter) is bad. It has enough power to light the red LED, but not enough to power the TV.http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=12+volt+5+amp+power+supply&_sacat=See-All-Categories
May 23, 2009 | Proscan 19LA25Q 19 in. LCD Television
DLP HDTV shut off, sound but no picture
replace light bulb,
if you are hearing a click like the stove is because the lamp balast is trying to power on the lamp,
if you need part number and vendor please send me the model number
Apr 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My xbox 360 has no picture but sound only no red lights green ok
First take off my hard drive on the 360. Then plug it to the tv not with HDTV (use the red, yellow and white make sure it is on tv not HDTV) because it will not work for HDTV setting . then plugit into the wall with the 360 laying down not up and down and turned it on. (no picture but sound) with the 360 on take 1 towel fold it long ways and wraped it around 360 from back to front (make sure you cover the fans in the back to make it over heat.) leave your 360 on until it red rings (you can hear the 360 quit down. it takes about 15-30 mins depending on how fast it over heats. once this happens unwrap the 360 and turn it off wait 5 secs and power it back on and there you go you should have picture and sound again. if you still have problem you can now can send it to get repaired since there is a 3 year warrenty for red ringed 360's.
Feb 15, 2009 | Microsoft Xbox 360 Console
Tv turns on but no picture just a red blinking light stays on
Red light blinking means there's a problem in the TV....
What kind of tv is it?
Feb 10, 2009 | Televison & Video
Mitsubishi 65" DLP HDTV, Status light is red, no picture
Check your lamp; it may have blown. Sound, no picture and a red light are classis signs a lamp has failed.
Feb 02, 2009 | Mitsubishi WD-62528 62 in. LCD Television
Mits 62525
take the lamp back out and reset the lamp
Dec 27, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-65731 65" HDTV Logo
716 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
