Question about Hotpoint WMA54 Front Load Washer
What do the brushes on the motor look like? - Hotpoint WMA54 Front Load Washer
  • 159 Answers
They are carbon brushes.there is 2 of them,the brush itself looks like lead like in a pencil,they rub on the motor as it spins providing electricity to the motor.they are spring loaded to push onto the motor.most brushes are external & you can see them but others are incased inside the motor.brushes are allways at one end of the motor with a single wire plugging on to it.
Posted on Jun 03, 2010
Bissell Proheat 1383 removing brush motor to replace it with a new one.
May be a burned out collector of the armaturebetween the brush holder and armature ballbearings are maybe poor change the motor , and replace allways 2 brushes if its possible because 1 fieldcoil stator of the motor should have a problem if 1 brush is shorter than the other brush there is a disbalans with 1 long and a short brush , in the early years 50 60 or the more expensive vaccuums like Kirby 600 W motors
it is useful to change brushes buit in 60% of the cases you lost the brushes again in 1 month .
Oct 29, 2015 | Vacuums
How to locate the washing machine brushes?
Some motors do not have carbon Brushes as its a induction motor as a opposed to a reaction motor which does have, not sure about your model but you could check this first, if it does have a brush kit fitted they should be easy to identify and remove if on the other hand no brushes then you would need to fit a new motor. On the bosch the brushes can be hidden look at the back of the motor ,you will see two wires one for each brush connected. Good luck.
Jun 03, 2014 | Bosch Nexxt Premium WFMC6400UC Front Load...
I have a pride 1170xl with E675HT motors. I broke the black plastic brush holder getting the brush out. Can the brush holder be replaced separately or do I need to buy the whole MOTOR END CAP? I may be...
Mark,
The manufacturer parts manual indicates the following information:
The motor brush caps are available from Pride:
PLSINDV1059 Motor brush cap (Reliance 0003-0035) retail $2.68
The brushes are:
DRVBRSH1000 Motor brush Jazzy (Reliance 0002-6957) retail $36.31
The guys in tech service at Pride (800-800-8586) are always a good resource for the information you may need. If you are exceptionally nice to them they will drop a new brush cap in the mail for you for free.
You can also check with Reliance Motors at their website for information and cross reference for other brushes available based on the Reliance part numbers above.
A good local motor rebuild shop can recommend a comparable (more durable) brush based on the specs. I think you may be disappointed with the pricing of the more durable brushes.
You can try on-line at:
http://www.graphitestore.com/items_list.asp/action/prod/prd_id/255/cat_id/37
Hope this helps.
Feb 06, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
HI; How do i change the brushes in an electric
Motors with carbon brush can be detected due to the two brush access at two opposite sides. Open this up,
and you can already change the carbon brush.
However, if your motor doesn't brush access, the probability is your motor is a capacitor motor. Replacing
the capacitors will restore your motor proper speed.
Oct 27, 2009 | Coleman Powermate 4 Gallon Air Compressor
Need to replace motor brushes on Kenmore canister vacuum 116.25914503 - Getting lots of arcing at brush ends. Need tear-down steps to get at the brushes.
If you can see the arcing you are likely in the motor housing. The brushes are specific to the motor depending on RPM. Most brushes and motors in Sears units are supplied by AMTEK Lamb. The color on the plastic housing and stamped model # on motor will help identify the correct carbon brush, however new brushes will NOT always solve your problem if the motor is arcing.
If the armature is worn like an apple core or if the lines between segments on the copper commutator are gaping and not parallel you will need a new or rebuilt motor.
If brushes are properly removed there is a tiny flag terminal which will slide out of most brush housings where the wire meets the brush itself. New brushes are best installed after dressing the armature surface with a fine carbarundum seating stone or very fine wet dry sandpaper and then the motor is run in at half speed at reduced voltage.
|There is usually a hold down clamp over each brush to seat it and a lock tab underneath to align the new brush.
Sep 30, 2009 | Vacuums
Hotpoint BHWM129. Cannot change brushes.
there are no brushes in that kind of motor
Aug 16, 2009 | Washing Machines
Changing the brushes when the motor is off
Remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if they are any shorter than 1 cm replace brushes.
Nov 16, 2008 | Bosch Classixx WFC 2465 Front Load Washer
HO DO YOU FIT BRUSHES TO A WFR2866GB WASHING MASHINE
remove motor,
remove motor brush cover screws from the motor
shake out old brushes
insert new brushes, spring side out
install brush cover screws
install motor
Sep 27, 2008 | Bosch Washing Machines
Bosch wfr2460
hi Many universal motor malfunctions are caused by wearing down of the carbon brushes, the soft blocks of carbon that complete the electrical contact to the motor's commutator. When these brushes become worn, the motor will spark, and electrical contact may be incomplete.try this
Step 1: To sight-check the carbon brushes, remove the screws that hold the brushes and brush springs into the brush holders at the sides of the commutator. The screws will pop out of the screw holes; turn the motor over to tap out the brushes. The ends of the brushes should be curved to fit the commutator; if they're worn down, new brushes are needed.
Step 2: To check carbon brushes with a continuity tester, remove the motor lead wires from the circuit. Tag the wires as you disconnect them so that you'll be able to reconnect them properly. Hook the tester clip to one motor lead and touch the probe to the other lead; the tester should light or buzz. Slowly rotate the motor shaft, keeping the tester in position. If the tester doesn't light or buzz, or if it flickers or stutters when you turn the motor shaft, the brushes should be replaced. If the springs behind the brushes are damaged, they should be replaced as well.
Step 3: Replace worn carbon brushes and damaged springs with new ones made specifically for the motor. The model information (number and make) is stamped on a metal plate fastened to the motor, or embossed on the metal housing of the motor. If you can't find the model information, take the worn brushes and springs with you to an appliance-parts store to make sure you get the right kind. Insert the new springs and brushes in the brush holders, replace the brush assemblies, and secure the new brushes with the mounting screws that held the old brushes.
Sep 13, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Bissell upright vac, brush on bottom does not rotate
The front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
May 21, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Hotpoint WMA54 Front Load Washer Logo
202 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
