Question about KitchenAid KGSS907SSS Gas Kitchen Range
The oven is not working. The control panel is showing pre heating but no ignition. How can I check the ignator?
  • KitchenAid Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on Jun 04, 2010
The oven will pre heat to set temp, then when it reaches temp the oven beeps and both oven elements turn off. At this point the control panel (clock LED) shows an F2 error.
Good afternoon.
F2 for hotpoint means oven temp sensor thinks oven exceeded 650 degrees .Did that happen?
Probably not so have your sensor checked or replaced. It should be a probe device in oven back wall.
Was this helpful?
Aug 16, 2011 | Hotpoint RB787 Electric Kitchen Range
Bake pre heat isn't working broil and top burners
heatman101
Aug 07, 2011 | GE Ovens
My oven does not heat up. Control panel lights up; oven igniter does not light up. I have oven igniter checked and said it is not the problem. What else can I check? Thanks...
heatman101
Aug 03, 2011 | GE Spectra JGBP35 Gas Kitchen Range
I HAVE A kENMORE GAS RANGE MODEL 665.75776890. tHE OVEN DOES NOT IGNITE. YOU CAN SEE A GLOW BELOW BUT IT NEVER IGNITES TO PRE-HEAT. CAN THIS BE FIXED BY REPLACING A PART?
Oven not Working or
Oven not Heating
Oven Problems
heatman101
Dec 12, 2010 | Ovens
Whirlpool Gold model #GS395LEG oven control panel shows it is preheating, but you don't hear the click and the gas doesn't ignite. Ten minutes later, no heat!
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 09, 2010 | Whirlpool RBD305PD Electric Double Oven
GE Gas Range Over Won't Heat
Hello, Yes this is going to be the bake igniter. If you remove the lower panel in the oven you will see the bake igniter. It may still be working when you switch on the oven but it is not getting up to the correct temp in order to ignite the gas. Replace the igniter and you will be all set. If you have any other questions please feel free to comment. Good Luck! Mike
Oct 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Hotpoint Gas oven doesn't light
Is the gas valve easy to replace on a gas oven?
Nov 14, 2008 | Hotpoint RGB745 Gas Kitchen Range
The oven doesn't work ,the ignator doesn't light up. no gas coming
The technical jargon is,.....:
In order for your gas oven to work this is what has to happen: 1. when you turn on the oven, the range sends 120 volts to the glow bar igniter. 2. as the igniter heats up (and starts to glow) it starts using more electricity. 3. when the electric use reaches a set amount (say 3.2 amps) the range knows the glow bar igniter is hot enough to ignite the gas, so it then releases gas through the gas safety valve. 4. when the thermostat tells the oven controller that the temperature has been reached, the control cuts power to the igniter, cutting the amp draw down, causing the safety gas valve to close. 5. process repeats to hold oven temp until you turn off oven.
So,..........the solution is:
most likely your oven igniter burnt out. Find your model number, usually on the range frame just behind the lower drawer or broiler drawer (depending on if it is a self clean gas range or not) and order the correct igniter and replace it.
Nov 02, 2008 | Kitchen Ranges
Oven Ignation would not Stop flickering after ignation
This is usually due to the "brain" of the stove going bad, better known as the control module... not an expensive fix if you can find the part and due it yourself... you can locate it iether in the back right corner when you lift the stove top or it's under an access panel below your broiler drawer depending on model.
Jan 15, 2008 | Brown Stove Works TM110-3 Gas Kitchen...
Oven won't start
If you look at the oven igniter in the bottom portion of the range, (where the gas controls are) look to see if the igniter is glowing hot. If not, replace your igniter. This is the part that starts the burner and keep it lit. When you get a new igniter DO NOT TOUCH THE ELEMENT PORTION of the igniter. Or it will pre-maturly fail. Good luck.Hope this helped ya!
Dec 07, 2007 | Frigidaire FGF378AC Gas Kitchen Range
KitchenAid KGSS907SSS Gas Kitchen Range Logo
274 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
