Question about Neff B1641 Single circotherm super Electric Oven
Power tripping off at mains when switching oven on
Power tripping off when switching oven on
  • Neff Master
  • 3,463 Answers
It will probably be the main oven element that has failed.
This is located at the rear of the inner oven compartment behind a removeable cover.
Posted on Jun 03, 2010
Why does it trip breaker?
There probably is an internal short.
Oct 04, 2015 | Neff Ovens
My range oven has tripped the power and now it's not heating up. However this grill is still working. What could be the problem?
one of the elements has gone
this tripped the power off
now the element is prob switched off
if you switch on the unit again it will trip or not work and do nothing to the power
you need a new element
try ebay if you want to do it yourself
usually one screw and two connections per element
{power off at the mains to the unit}
or what i would do is buy the element and get a tech to do it
saves time and added cash they will add to the cost of the parts
Apr 19, 2015 | Ovens
Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Sep 05, 2012 | Ovens
Main oven causes trip switch to trip out when `I turn the dial to switch on. Top oven is fine.
Likely the element is shorted in the main oven. The Calrod elements short usually at the bends and if the breaker doesn't trip they burn a hole in them and arc. You can USUALLY see a different discoloration at teh failure point. Check both upper and lower elements as preheat probably uses both. Use a dental mirror if necessary to see under and over. Use bright light.
May 04, 2011 | Tecnik TKC8525 Double Oven
When I was using main oven elecric tripped, when the fuse is push back in and oven isolation switch turned back on the electric is constantly tripping only when cooker isolation is turned on, oven element...
Sounds to me to me like a direct short. Hot wire in unit could be touching part of unit. Oven switch if it has one or main board could be shorted. Oven will have to be pulled to check. Slimm possibility weak breaker.
Mar 02, 2011 | New World Ovens
Oven keeps tripping mains
If it is a electric oven, then the chances are it is the oven element that is causing the problem.
What is probably happening is that as the element gets hotter, the insulation resistance is breaking down, and causing the trip to operate
Hope this helps.
Feb 02, 2010 | Whirlpool Ovens
Neff U1421 main oven trips the circuit breaker.
It might be that the breaker is overloaded and it's no longer supporting the load of all the appliances together.If you do not want to change your breaker you can still use your oven by switching off other appliances that is running while you are using the oven
Feb 04, 2009 | Neff U1421 Double circotherm Electric Oven
Smeg oven problem
The pop would usually mean a busted fuse. Turn off the oven, disconnect completely from the power supply and then take it apart. See if you can find any toasted fuse or roasted wires. Also the reason for tripping the mains off is due to the fact that the oven is draining more power than it should. I would recommend a thorough inspection of the oven by an electrician..
Jun 18, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Neff B1641 Single circotherm super Electric Oven Logo
378 people viewed this question
Top Neff Ovens Experts
ashburton
paulcarew
bobby1964
Level 1 Expert
Are you a Neff Oven Expert? Answer questions, earn points and help others
