Question about GE Refrigerators
Gsh22kgmd fridge is 52 dgrees and freezer is 10
Gsh22kgmd fridge is 52 dgrees and freezer is 10 degrees both settings at 6.
have replaced circut board on back once in mar.
catriver
  • 878 Answers
SOURCE: Kenmore trio 569. Fridge No getting cold Temp is now 81 degrees Freezer ice cold
Mark, check to see if the fan is running in the freezer section. Common problem on these 596's trios. If the fan is running, you might have a defrost problem. If it isn't, your part number for the motor is 67002778. No fan, no cool upstairs...Catriver..post back.
Posted on Mar 04, 2007
  • 686 Answers
SOURCE: fridge part is 50 degrees and not cooling while
do you feel the fan blowing cold air from the freezer to the fridge?
Posted on May 02, 2009
  • 61 Answers
SOURCE: Refrigerator does not maintain 37 degrees
i have seen this problem before its the control board in the back the board is about 150 dollars and it goes every DING DING 5 years lol horrible design of the one that comes on the fridge every ge side by side has this problem  its very easy to replace but have to "ground" yourself before you touch the new control board meaning rub you hands on plumbing pipes, not pvc or copper
good luck if you got questoins let me know
Posted on Jun 08, 2009
dnewcombe1
  • 1564 Answers
SOURCE: RM 2611 freezer works but fridge does not get
Check when you turn the control knob inside the fridge side that there is some form of resistance or at least a sweeping sound. The knob will always stop at both extremes but very often the linkage can come loose leaving all the cool air above in the freezer. if you can unplug the fridge and listen very closely to see if the deflection door is indeed moving. If you can get the cover off, grab your surgeons cap, a flash light and a long pair of needlenose pliers you may be able to clip the link back in place. Good Luck,Dana
Posted on Aug 16, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Our refriderator (GE Profile) keeps losing its
With a Profile the problem is most times the defrost heater has burned out.I have yet to see the control board be the reason. Look into rear of freezer on rear panel if not defrosting it will have a frost line creeping up the panel wall. The defrost heaters for your model have glass tubes surrounding the heating element and most times one you get the ice melted away yo can see black marks inside glass where it burned out. So if you want to do this yourself unplug and remove the rear panel and defrost with a hair drier to speed things up. It may take about two more days before this begins so plan on saving all you can somewhere else. I know, yea right! Anyway things could be worse. I will list the parts you will need and contact info, Thanks Sea Breeze
Posted on Apr 11, 2010
Hi, my refrigerator Panasonic NR-B320T non stop running, both vegetable and freezer sections are GETTING FREEZED even though the temperature are set at 1 (cold not at 3, the coldest).
check your user hand book as most fridge settings work the lower the number the colder the setting
so 1 is around 1-3 degrees , 3 is 4-6 degrees, 4 is 7-10 degrees
it is the freezer that works 1 is minus 5 and 5 is minus 20 degrees
it would explain why everything is freezing up
it would also explain the non stop running as the fridge is battling to keep the low setting
Nov 23, 2016 | Panasonic Refrigerators
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 | Freezers
The freezer is 10 below but the fridge wont cool lower than 52 degrees
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | GE Refrigerators
Refrigerator temperature is set at 37 dgrees but the temperature has gone up to 60 degrees. Freezer is ok
heatman101
Compressor overheated and shut down.
Pleas put setting in the middle and give it 24 hrs and check temps
freezer would be good at 0 to 10 f
I thing you have the damper door closed.
May 24, 2010 | Whirlpool GS6NBEXR Side by Side...
Freezer side cold fresh side not GE GSH22KGMD
Find the return air It can't come in if it can't get out. also if you were checking it with the freezer door open you will not feel the air. Just in case i have done that myself. if all air ducts are open and it's getting o I should be 20 in fresh food with the control on 9.
Sep 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer cold fridge 52 degrees
We have a Kenmore Coldspot Model # 106.8770687 and the freezer is cold and keeping things frozen, but seems to be frosting over and the refrigerator is warm at 40 to 50 degrees ... any help regarding what to check is helpful! Or a schematic / manual
Jun 14, 2009 | Kenmore Refrigerators
FREEZER KEEPS ICING UP
lol.. welcome to my world... I have my fridge set at the lowest without turning it off...IT FREEZES a gallon of tea in 5 days!! My freezer ices some.. its set at 3..(1-6).. BUT I like keeping frozen foods FROZEN.. I deal with the ice...
I have asked several repairmen.. they just guess...I am NOT going to spend money for something that is a GREAT Frig/Freezer.. better than TOO HOT and ruining food!!
Sep 24, 2017 | Amana ARB8057CSL Bottom Freezer...
Mar 04, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
