Question about Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ Bottom Freezer French Door Refrigerator
My refrigerator is not cold however my freezer is working. What could be wrong?
  • Amana Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
RefrigeratorMy refrigerator is not cold however my freezer is - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 04, 2010
mikedurland
  • 481 Answers
SOURCE: refrigerator not getting cold - freezer still pretty cold - perhaps not all the way
Sounds like a defrost problem or dirty coils under the machine. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Aug 12, 2008
  • 214 Answers
SOURCE: REFRIGERATOR NOT COLD
I have experienced this also.
If the drain under the evaporator coils in the freezer freezes up it will cause this. Because the coils ice up. Manual defrosting with hair dryer will get working again, but if drain is stopped up it repeat.
Maybe piece of paper or food in it.
OR the defroster heater element is burnt out. Same results.
Most all top Freezer Models.
Posted on Nov 13, 2008
  • 1214 Answers
SOURCE: My Refrigerator and Freezer is warm
Chances are if they are getting cool -
1) the evaporator fan in the freezer is not running
2) Defrost heater has failed
3) Defrost sensor has failed
4) Defrost timer/refrigerator control has failed.
Check for ice build-up on the back wall of the freezer. If there is ice, unplug or turn the unit off for 6-8 hours with the doors open (put any food in a cooler with ice to maintain). Note water may come out of the refrigerator.
Plug the unit back in or turn it back on, close the doors, and check temperature after a couple of hours of operation. If all OK, you will need to have the above tested, or, if you know how to use a multimeter and can read a schematic/wiring diagram, I can instruct you on how to check the above.
Posted on Jan 15, 2009
  • 479 Answers
SOURCE: freezer working refrigerator not getting cold
Check the back wall or floor of the freezer section for frost. Check the freezer( evaporator) fan to see if it is running. Check the condenser coils( under the unit ) for blockage from dust. Check the condenser fan (under the unit) to see if it is running.
If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. These things usually require dismantling the freezer and other areas of the refrigerator to be checked.
You could defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with BOTH DOORS WIDE OPEN to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
Posted on Jan 05, 2010
woodchuck789
  • 4059 Answers
SOURCE: My freezer works but my
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Sep 26, 2010
Refrig is not staying cold, power works, light on, freezer works.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 17, 2011 | Maytag 22 cu. ft. Bottom Freezer...
Refrigerator section not cold, freezer cold and working
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 19, 2011 | Maytag Ice2O 19.8 Cu. Ft. Side-by-Side...
The freezer portion works, the fan and light in refrigerator section works but Fridge does not get cold
heatman101
Jan 25, 2011 | Amana ARB2257CSR Bottom Freezer...
Refrigerator is not cold. Freezer still works
heatman101
Dec 17, 2010 | Maytag MFD2560HES Bottom Freezer French...
Freezer works, it's cool nolt cold in the refrigerator, fan motor doesn;t seem to be working
heatman101
Oct 19, 2010 | Roper RT14DKX Top Freezer Refrigerator
Fridge not working (light on - not cold) and freezer working fine.
heatman101
Oct 18, 2010 | Hotpoint FFA70 Bottom Freezer Refrigerator
Freezer cold and working fine, fridge not getting very cold. Have defrosted freezer, removed freezer back cover fan all working o.k. Jim
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 24, 2010 | Amana ATB2135HR Top Freezer Refrigerator
Freezer is working fine. The refrigerator is not
heatman101
Aug 02, 2010 | KitchenAid KSCS25FKSS Side by Side...
Freezer works but fridge doesn't stay cold
heatman101
Jul 16, 2010 | Maytag MSD2756G Side by Side Refrigerator
Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ Bottom Freezer French Door Refrigerator Logo
93 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
