Question about HP OfficeJet 6110 All-In-One InkJet Printer
Printing out of registration on left side - HP OfficeJet 6110 All-In-One InkJet Printer
    Guru:
  • HP Expert
  • 314 Answers
If you are getting the registration windows check the following steps :
click Start - click All Programs - Accessories- System Tools - Under Name - click and delete any task that starts with Webreg - Scheduled Tasks
Posted on Jun 03, 2010
Line through print
Perhaps did not specify paper thickness (check control panel and print driver).
Toner getting low.
Clean registration roller with clean damp cloth.
Aug 17, 2012 | Ricoh Aficio SP C811DN Laser Printer
Hp laserjet 1320 after printing blank paper appair
Hi Naveed Khan
It looks like any toner inserted will have the same problem. You need to check the left side springs of High Voltage. There are two springs inside. One you can find on the left side of the registration assy. with a small steel piece attached on top this is a spring causing you the trouble. Try to pull the spring out from the plastic as the cartridge is not able to get the high voltage it is not able to perform the Image formation.
Thanks
Saleem Ahmed
Mysore
Dec 13, 2011 | HP Office Equipment & Supplies
My Ricoh 7300 is printing but all the color are not lining up
Try running auto color registration adj from user tools/menu(try it a couple times)
If this doesnt clear it up you will need to have a transfer belt and or transfer belt assy replaced
--Drew
Dec 11, 2009 | Ricoh Aficio AP3800C Laser Printer
Starts printing half way down the page
open the top cove ,right and left cover in right side of the printer you will see three spanger replace the spanger which one touched to registration unit ........... clean the registration unit and check..........
Oct 26, 2009 | Kyocera Mita FS 1010 Laser Printer
Registration of colors. The magenta and cyan are alittle offset from the black. I can get into registration mode but do not know which keys to hit to adjust.
When you get to registration mode, press enter, then execute will appear, then press enter. Then display will say adjusting. Remember magenta, cyan and yellow register to black. If registration is still bad you need to remove the four drums and transfer belt. To the left you will see a plastic move it to the left and you will see a white plastic with two sensor one at each end. This clear plastic get dirty and then you have bad registration. Clean it with a Q-tip. This two sensors are locate just below the left of the transfer belt, one at each side. This usually get dirty with residue of toner.
Jul 06, 2009 | Xante Ilumina Digital Color Press Printer
Fuzzy prints, paper jam
If you would like the service manual reply with your email address (it's 5.87mb).
Your first problem could be caused by one of the following, feed roller from the paper tray is slipping making the paper to leave the tray late causing the registration sensor to flag an error because it hasn't detected the paper quick enough or the registration sensor is just not working, could even be the paper feed clutch or registration clutch. I don't think the problem is with the thin rollers.
The second problem could be a few things, possibly a consumable, i would start by swapping the consumables over between the two machines, transfer unit, transfer roller, cleaning roller, photo developers, fuser etc, if that doesn't cure the fault clean the hv connections. This problem is related to the high voltage so investigate in that area.
Sorry for being long winded, but without being in front of your printers its a bit of a guessing game.
Apr 08, 2009 | Lexmark C510 Laser Printer
Sketchy printing along left margin of paper
Very Likely to be the Fusing unit.
I believe on that model it is located just inside the front door. Held in with two levers and a cable.
Inspect the Hot roller of the fusing unit, to see if it is worn.
Sep 26, 2008 | Ricoh Aficio CL2000N Laser Printer
PRINTER CUTS OFF RIGHT SIDE OF PAPER
First, on your computer desktop. left click on START. Next, left click on CONTROL PANEL, and left click on PRINTERS. Find your printer on the PRINTERS window, and RIGHT CLICK on the icon. From the drop-down menu, left click on PRINTING PREFERENCES. Use the settings to set up the printer for the paper size and orientation you want to use.Click APPLY , then OK buttons to apply any changes you make. If that does not help,check the side paper guides in the paper source you are using. If they are not against the paper on both sides, the paper will not align properly with the image. Move the guides snug but not tight against the paper. If the guides are too tight, paper may not feed. If moving the guides does not solve the problem, try loosening the guides and reposition the paper until the image is properly aligned. Then see in your owners manual if there is an adjustment called SIDE-TO-SIDE REGISTRATION, and follow the proceedure to adjust the side-to side paper alignment.
Jul 16, 2008 | Dell 3100cn Laser Printer
Registration problem
ADJUST REGISTRATION ON THE PCB BOARD AND ALSO THE BIAS VOLTAGES
May 13, 2007 | Canon imageRUNNER C3200 Copier
HP OfficeJet 6110 All-In-One InkJet Printer Logo
41 people viewed this question
Seeker5211
Seeker5211
