Question about Radio Communications
Will not ring or vibrate
Please help, I have a cobra PR4700 WX and I have tried everything but it will not ring or vibrate. I can still get calls and send calls but it does not give a call alert. I have followed all the instructions as I use about 10 of these at work.
Try using the earbud(if included). The earpiece worked for our motorola t5700 unit at work. It had a blown main speaker.
good luck
Posted on May 26, 2008
Cobra microtalk pr4700 wx power shuts off if you press talk
Try new batteries. If it still happens, clean the battery contacts with sandpaper and try again. This occurs when there is no enough power to transmit from your power source, which are batteries! Let us know!
Apr 09, 2017 | Cobra Radio Communications
One of my Cobra Microtalk radios is stuck on RX. Everything else seems to work. What could be the problem?
Hi!
Almost always, the problem here is that the micro switch for the Push-to-Talk (PTT) button has failed. Your radio should have a warranty, but even if the warranty has run out, it isn't horribly spendy to fix. I'd get in touch with Cobra Electronics, I have heard they're extremely helpful. Try this link and good luck!
https://www.cobra.com/help/
Jul 05, 2011 | Cobra Electronics microTALK® PR 3850 WX ...
Cobra 75 wx st no sound/speaker does not work. Everything else seems OK according to display
Hi, my name is John. try putting a external speaker in back of radio and see what happens, might need to replace internal speaker, or something internal. Let me know, I will post the process here......Hope this was helpful..
Aug 01, 2010 | Cobra 75 WX ST 40-Channels Handheld CB...
Everthing on the radios work but there is no sound from the speaker.The RX shows on the display and the the vibrate work when called. Whats up?
#1 bad speaker, #2 external speaker jack bad/shorted, #3 volume control bad/open, #4 squelch control bad, & #5 is it both radios no audio?
May 13, 2010 | Cobra microTALK LI 7200-2 WX VP Two Way...
Cobra 18 wx st for mobile use, ned to switch reg mic for cherokee power mic. need mic diagram for the four pin
You probably don't want to hear this, but the cobra 18 wx st is just about the worst, and most hated radio ever made. Its a very poor radio.
to be very honest with you, you should get rid of that radio, or return it. Then buy a cobra 29 instead,
for proper mic wiring, please reference this page.
Jan 03, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
My 18 WX ST Cobra CB radio will allow me to receive sound from the 3 weather stations it has on it, but I cannot pick up sound from other CB radios. help please?
get an swr meter and check your antenna first. if good problem may be in the circuit board.. they are famous for loose IF, TX mixer boards. or call us
Nov 03, 2009 | Cobra 18 WX ST 40-Channels Base CB Radio
Cobra 75 wx st everything seems to work eccept receiving signal meter will spike on trx and it seems to receive but no sound there is sound in wx mode
WX is for weather. If you put it on WX, and you do not hear anything, then you need to change the weather station it is on. in wx mode, you change weather channels by pressing channel up and down. To communicate with 2 way, press the cb/wx button so it is on CB mode.
Sep 28, 2009 | Cobra 75 WX ST 40-Channels Handheld CB...
Weather bleads Over on 21 LTD WX CLASSIC(*HELP*)
sounds like your wx receiver is being activated by a bad switch replace the switch to disable the wx when you dont want it to come thru
Jun 10, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 75 WX ST 40-Channels Handheld CB Radio manual/antenna
Hi - You can download the manual from the link underlined in blue below:
75 WX ST
Other info here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 31, 2008 | Cobra 75 WX ST 40-Channels Handheld CB...
Radio is switched on vibrates and goes directly to a blank screen
The problem that you discribe, sounds weird, check if the radio battery connectors are clean, if the radios are new, I think you must to cliam the warranty.
Feb 19, 2007 | Cobra MicroTalk PR 4200-2 WX (22 Channels)...
Radio Communications Logo
57 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
