Question about Magellan Maestro 4000 GPS
Magellan GPS does not go on at all
My magellan maestro does not go on at all. It's only 2 years old. Should I try a replacement connector/charger?
Thank you!
    President:
  • 1,111 Answers
The folowing advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your Magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
bill
Posted on Jun 04, 2010
My Magellan Maestro 31100 won't power on
You could have a defective power connection in your Magellan Maestro 3100 which will not allow you to charge the internal battery or power on your unit.
You may try to contact Magellangps.com or Autonav2000.com to see if they can provide you with repair service.
Might be cheaper to purhcase another Magellan Maestro than spend the money on repairs.
Good Luck
Apr 03, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
Will not charge thru the USB or the car charger. Is the battery replaceable?
a magellan 4040 can not charge through the USB port and if it wont charge with a known good car or home charger, then read below.
This is very common problem with this and many model of magellans.
Try the car charger.
Make sure
green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 2000, 2200t, 2500, 3000, 3100, 3140, 3000, 3050, 4000, 4040, 4050, 5310 and the 6000 are known to have faulty dc connectors...if your Magellan
gps is not charging or will not power up, its most likely the dc power port...
You can
buy the port or get it repaired, HERE
if the links dont work or If you need further help, just let me know.
Jan 18, 2010 | Magellan Maestro 4040 GPS Receiver
Magellan maestro 3100 will not hold a charge
this is very common problem with this and many model magellans.
try the car charger.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Dec 02, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
I can't tell if my magellan maestro 4000 gps is charging.
this could be happening for a few reasons but the most common is that its probably not charging.
before checking anything else, plug your 4000 in to a known good charger, then press and hold the power button for up to ten seconds till it starts.
if that fails, its likely not charging
you can get help to repaired it, here
Nov 09, 2009 | Magellan Maestro 4000 GPS
My Magellan Maestro 3100 GPS unit won't charge anymore. I've seen 2 possible explanations for this problem. #1: The DC power port is broken #2: The battery won't hold a charge any longer How do I determine...
if it starts, you can verifiy if its charging by going to the system settings then power options. the green indicator should be moving left to right. this indicates its charging.
if you disconnect the battery, your magellan should still work while plugged in if the power port is ok.
Oct 15, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Power cord is not charging unit. There seems to be a loose fit in the socket of the Magellan Maestro 4000. Is the problem with the charger cord or the Maestro 4000 socket?
its probably not charging...very common problem with this and many others.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040,4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
Oct 09, 2009 | Magellan Maestro 4000 GPS
My GPS Maestro Magellan just died again. What is the problem?
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040 and the 4050 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...i sell these power ports and will repair them for anyone thats not able to do it themselves.
Jul 27, 2009 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 4250 needs a battery
There is a kit that includes battery, tools, and how-to video available here.
May 22, 2009 | Magellan Maestro 4250 GPS
Magellan maestro screen not coming on
if you have a 3100 or 3140 as you have pictured..they cant be charged via USB..you need a home or car charger
May 10, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan Maestro 4000 GPS Logo
180 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
