Sony RDR-VX420 DVD Recorder/VCR Logo
Posted on Jun 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant get pre-recorded disc's to play in my recorder it comes up with the message "this disc will neither play or record" any ideas?
Anonymous
Level 3:
  • Master 484 Answers
  • Posted on Jun 03, 2010
Anonymous
Master
Level 3:
Answers
484
Questions
0
Helped
163061
Points
1488
the reason the recorder comes up with the message "this disc wont play or record" simply is that the format of the disc is not compatible with the player.
1. check the format of the recorded disc,
2. and check the formats the recorder can play to confirm this.
take care
How do i record my own message
Recording Outgoing Messages:
1. Hold the ANNC-DAYand speak clearly into the microphone.
2. Release the ANNC-DAY when you finish. Your answering machine beeps and automatically plays back your recorded message.
Message limit:
60 seconds
To re-activate pre-recorded message:
Press "delete" during while playing your outgoing message. The pre-recorded message is now activated.
1helpful
I lost manual. I need to know change message when will be out of town answering message.
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a
call: "Hello, no one is available to take your call. Please leave a message after the tone." You can record your own
personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
Press /mute. The system announces the number of new and old messages, then starts to play the
messages unless it has no messages.
Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the
system is in the command waiting mode.
Press 8 to start the recording. The system announces, "Record greeting." Begin recording after the
announcement.
When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded
greeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can
also switch back and forth between the pre-recorded greeting and your own greeting at any time.
Press 6. The system plays the current greeting.
To keep this greeting: Do nothing..
To switch to the other greeting: Press 6 while the system is playing the current greeting.
Each time you press 6, the system switches between the pre-recorded and the personal greeting. The last
greeting you hear is used as the current greeting.
Deleting Your Personal Greeting
You can delete your personal greeting from the base. You cannot delete the pre-recorded greeting.
Press 6. The system plays the current greeting. Switch to your personal greeting if necessary. (See the previous
section to switch the greeting.)
While the personal greeting is playing, press 4.
The system announces "Greeting has been deleted," and switches back to the pre-recorded greeting.
7helpful
I have the Uniden 6.0 Dect 1580-3 but there was ...
43
43
h
e
s
t
e
m
Your.answering.system.comes.with.a.pre-recorded.outgoing.message.or.greeting.that.plays.when.you.receive.a.
call:.“Hello,.no.one.is.available.to.take.your.call..Please.leave.a.message.after.the.tone.”.You.can.record.your.own.
personal.outgoing.greeting..Your.recorded.greeting.must.be.between.two.seconds.and.thirty.seconds.long.
1).Press. /MUTE..The.system.announces.the.number.of.new.and.old.messages,.then.starts.to.play.the.
messages.unless.it.has.no.messages..
2).Press.5.to.stop.the.announcements.or.message.playback..You.will.hear.intermittent.beeps.indicating.that.the.
system.is.in.the.command.waiting.mode.
3).Press.8.to.start.the.recording..The.system.announces,.“Record.greeting.”.Begin.recording.after.the.
announcement..
4).When.you.finish.recording,.press.8.again.or.press.5..You.will.hear.a.confirmation.tone,.and.your.recorded.
greeting.plays.back.for.you.
Once.you.have.recorded.a.personal.greeting,.the.phone.automatically.switches.to.your.personal.greeting..You.can.
also.switch.back.and.forth.between.the.pre-recorded.greeting.and.your.own.greeting.at.any.time.
3).Press.6..The.system.plays.the.current.greeting.
S
e
tt
in
g
U
p
t
h
e
A
n
sw
e
r
in
g
S
y
s
te
m 4).To keep this greeting:. Do.nothing.
To switch to the other greeting:.Press.6.while.the.system.is.playing.the.current.greeting.
5).Each.time.you.press.6,.the.system.switches.between.the.pre-recorded.and.the.personal.greeting..The.last.
greeting.you.hear.is.used.as.the.current.greeting.
You.can.delete.your.personal.greeting.from.the.base..You.cannot.delete.the.pre-recorded.greeting.
3).Press.6..The.system.plays.the.current.greeting..Switch.to.your.personal.greeting.if.necessary..(See.the.previous.
section.to.switch.the.greeting.)
4).While.the.personal.greeting.is.playing,.press.4.
5).The.system.announces.“Greeting.has.been.deleted,”.and.switches.back.to.the.pre-recorded.greeting.
3helpful
How to reset voice record on my panasonic KXTG9331T?
Greeting message
When the unit answers a call, callers are
greeted by a greeting message. You can
record your own greeting message or
use a pre-recorded greeting message.
Recording your greeting
message
You can record your own greeting
message (2 minutes max.).
1 {GREETING REC}
2 Within 10 seconds, press
{GREETING REC} again.
3 After the base unit beeps, speak
clearly about 20 cm (8 inches) away
from the MIC.
4 Press {?} (STOP) to stop recording.
Using a pre-recorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a prerecorded
greeting message for callers
and asks them to leave messages. If the
message recording time (page 39) is set
to “Greeting only”, caller messages
are not recorded and the unit plays a
different pre-recorded greeting message
asking callers to call again.
Playing back the greeting
message
Press {GREETING CHECK}.
Erasing your greeting
message
If you erase your own greeting message,
the unit plays a pre-recorded greeting
message for callers.
Press {GREETING CHECK}, and then
press {ERASE} while your greeting
message is playing.
Listening to messages
using the base unit
When new messages have been
recorded, the message indicator on the
base unit flashes.
Press {6}.
L If new messages have been recorded,
the base unit plays back new
messages.
L If there are no new messages, the
base unit plays back all messages.
Operating the answering
system
Key Operation
{^} or {V} Adjust the speaker
volume
{7} Repeat message
(during playback)*1
{8} Skip message
(during playback)
(STOP)
Pause message
– To resume playback,
press {6}.
– To stop playback
completely, press
{?} (STOP) again.
{ERASE} Erase currently playing
message
*1 If pressed within the first 5 seconds of
a message, the previous message is
played.
check if this works and tell me if any issues
68helpful
How do I change the outgoing message on my Uniden 6.0 1580??????? Digital answer machine.
call: “Hello, no one is available to take your call. Please leave a message after the tone.” You can record your own
Press 8 to start the recording. The system announces, “Record greeting.” Begin recording after the
announcement.
The system announces “Greeting has been deleted,” and switches back to the pre-recorded greeting.
Cheers!
Denon DMD-M10 minidisc recorder that doesn't record.
It shouldn't play any CDs as it is a minidisk recorder.
Try to stay on topic.
2answers
Dmr-ES30V Dvd plays pre record movies fine but I
Try a different brand of blank dvd+r or -r. you will find that your dvd machine is fussy on what discs it plays. More exspensive dvd players are fussy with what dvd discs you put in, as cheaper dvd players would virtualy play most types of dvds.
2helpful
The pre recorded message on the answering machine has been lost.
I read thru the manual. There is nothing bout recovery of factory messages. If you recorded your own, try deleting it. Or unplug the base from power and try a reset. This is from the manual. At the end, I gave you a link to the manual!
message
http://service.us.panasonic.com/OPERMANPDF/KXTG9331.PDF
2answers
Panasonic DMR-E50 won't recognise blank DVD's only
You can only record to dvd-ram or dvd-r NOT dvd-rw!
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
