I have a everstar ice maker it produces about 50 lbs a day, it will not keep making ice after it shutdown , it will not restart without me resetting the switch. Why?
  • leroyrainman Jun 03, 2010
    I shall see.....
  • 1,284 Answers
Hi, you have a minor problem with the control board which is why you have to reset it before it starts up. All you need do is get a tech to do a general servicing of the board and hopefully it will be restored back to it's normal way of operation...
Take care
Posted on Jun 03, 2010
Why is my ice maker making too much ice?
There is ar thin metal bar that checks for the level of ice on the bucket if the bar is bent our broken it will keep making ice all day
Sep 10, 2014 | KitchenAid 15 " Stainless Steel...
Everstar HDIM 35 ice maker
Click below ;
There's no ice
Hope this may help
Jul 30, 2008 | Freezers
Manitowoc troubleshooting
Clean the condenser thoroughly, descale and sanitise the waterways inside.
Feb 15, 2014 | Manitowoc Ice SM-50A Undercounter Ice...
My Whirpool Ice Maker Model GI15NDXTS won't stop making ice
check bin thermistor connection or replace it is inside the bin on the right side
Aug 04, 2012 | Whirlpool Gold Series GI15NDXT 15"...
Small production of ice? What should be the normal production of ice?
The way I understand how Hoshizaki machines work, the model number is usually what the unit will produce, in pounds of ice. Their manual states: "Approximate production/ 24 hours @ 70 degrees air/ 50 degrees water (incoming)" So, yours should be producing 450 pounds a day, approimately. Since I can not pin point your exact model, I found one that is close. It states: "Ice Production per cycle: 6.6 pounds, 360 pcs." Again, it is not you exact machine. Their web site does not show this model either. So this is the best info I can get for you. Hope this helps.
Jun 03, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Ice maker stopped
Hi!
Please check these:
It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
If your ice maker has a small red plastic lever, lower it to lower the wire.
If there's no plastic lever, simply lower the wire.
In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 23, 2009 | Whirlpool Gold Series GI15NDXT 15"...
DCE33 Ice Machine
I believe it was the inlet water valve that needed to be replaced, but I got so fed up with the noise and repairs on this machine that I purchased a Whirlpool ice maker. So far, it's been great. It is much more quiet and produces 50 lbs of ice in 12 hours and shuts off until some of it melts. It only produces more ice about four times a day as it melts.
Sep 27, 2008 | Refrigerators
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
Heating & Cooling Logo
55 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
