Mtd 22" Yard Machine Push Mower Logo
Anonymous Posted on Jun 03, 2010
MTD Yard Machines 22'' mower, pull cord won't extend
I have a Yard Machines 22'' rotary walk behind mower. The pull cord will not pull to full extension to start the mower. It will pull out a little and then seems to get stuck. Any assistance would be appreciated.
  • Anonymous Mar 22, 2014
    when pulling the cord its to tight can just about pull it it seems like its locking
Tim Green
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 14, 2015
Tim Green
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1394
Points
Found out that after unboxing the mower you have to pull the handle out 8 inches to a second set of holes for the T-bolts near the frame. Up under the frame of the mower the handles go down and block the blade from turning.
Mike Squire
Level 3:
  • Master 420 Answers
  • Posted on Jun 04, 2010
Mike Squire
Master
Level 3:
Answers
420
Questions
Helped
258547
Points
1000
From what you describe it sounds like the line may be tangled, remove the rewind housing in order to inspect the line up close.
1 Related Answer
mikehowy
Michael howard
  • 177 Answers
  • Posted on Jun 07, 2010
SOURCE: Yard Machines 22'' mower, pull cord won't extend
is it flooding or is it second hand , some people cut the cord and dont fit it back properly , if it is flooding you will get hydraulic lock , answer to your question is carby service and over haul
Repair lawn mower pull cord
Home Depot sells a replacement pull cord kit that has great instructions. My mower, however, had pop rivets holding the cover on the engine, so if yours does too, get a pop rivet tool with the correct size pop rivets before you start drilling out the old pop rivets.
How to remove spark plug
I have attached an article about how to change the spark plug on a walk behind mower.
The directions should be roughly the same despite the difference in brand and model.
I hope this helps!
How to Change the Spark Plug on Toro Recycler Self Propelled Mower
What is the cord length for the follwoing MTD model# 12A-46M9031
Hi there. Various countries sell the machine with various lengths of power cords. Normally 30meters, but have seen some machines sold with 10 meter cords. I guess it all depends on your yard size, and if you will reach the furthest point with the cord. Hope this helps
1helpful
2answers
Jun 03, 2010 • Garden
1helpful
2answers
My MTD walk behind lawn mower won't start. There's gas and spark (I think---when I looked at spark plug, it was pretty dirty and had a lot of dark greasy residue on it so I cleaned it off, but it still...
Make sure you have fresh clean fuel in the mower. Has the mower been setting for a while? Make sure your air cleaner is not plugged. Try starting with fresh fuel and the air cleaner off. Let me know if the cord tries to pull back or you have hit anything with the mower blade recently.
Recoil will not pull. The walk behind MTD,Yard Machine mower, a B&S 500 Series stalled while mowing. I went to restart and pull cord will not pull more then a few inches. How do I go about the fix?
If all the safety gear is working on the mower; Possibly sounds like you let it run low on oil and the engine is locked up.
Which would mean a new mower.
Sep 29, 2009 • Mtd Garden
Yard Machine won't start
Maybe the Spring is broken in the housing, that is assuming you are talking about a problem with the pull cord. Your question is kinda vaque. Submit more information !
Craftsman Walk behind lawnmower
usually theres just a few bolts to take off on the top, and the whole rip cord assembly will pull right out, allowing you to install the new one.
1helpful
Change Oil
All lawn mower engines have a drain plug for draining the oil. Look for a square nut on the side of the engine
Starter rope broke on yard machine
Take the top off. Remove broken rope. Rewind spring until tight, then unwind one turn. Insert and knot new rope.
Top Mtd Garden Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
john h
Are you a Mtd Garden Expert? Answer questions, earn points and help others
