Question about Garden
Yard Machines 22'' mower, pull cord won't extend
I have a Yard Machines 22'' rotary walk behind mower. The pull cord will not pull to full extension to start the mower. It will pull out a little and then seems to get stuck. Any assistance would be appreciated.
  • 177 Answers
Is it flooding or is it second hand , some people cut the cord and dont fit it back properly , if it is flooding you will get hydraulic lock , answer to your question is carby service and over haul
Posted on Jun 07, 2010
The cord is more than likely wrapped around the pin holding the reel in place.
I have a 11A-54MC006 21-Inch 139cc MTD OHV and that was the issue when My pull cord was stuck. A bolt that holds the entire pull cord "mechanism" tight had loosened. read your manual or try a website on how to put it back together. once you take it all a part. Check back if I find a good site or video even. I'll let you know. You'll need a metric socket set to take it apart. 7m-11 or 12m. Good luck brosef.
Posted on Sep 29, 2012
How do i take off the pull start from a craftsman model 917.377582 lawnmower
engine numbers would be helpful buttttt.... the perimeter of the recoil assy should be 3-5 small screws. remove them and it should come off, the is as long as you have a eagerbeaver engine ( tecumseh ohv )
Apr 15, 2015 | Sears Garden
MTD Yard Machines 22'' mower, pull cord won't extend
From what you describe it sounds like the line may be tangled, remove the rewind housing in order to inspect the line up close.
Jun 03, 2010 | Mtd 22" Yard Machine Push Mower
Yard machine mower start and quits
this sounds like faulty switch or more likely a break in the cord close to the where the the extension cord exits the machine.
Jan 28, 2010 | Mtd 22" Yard Machine Push Mower
My MTD walk behind lawn mower won't start. There's gas and spark (I think---when I looked at spark plug, it was pretty dirty and had a lot of dark greasy residue on it so I cleaned it off, but it still...
Make sure you have fresh clean fuel in the mower. Has the mower been setting for a while? Make sure your air cleaner is not plugged. Try starting with fresh fuel and the air cleaner off. Let me know if the cord tries to pull back or you have hit anything with the mower blade recently.
Nov 28, 2009 | Mtd 22" Yard Machine Push Mower
Recoil will not pull. The walk behind MTD,Yard Machine mower, a B&S 500 Series stalled while mowing. I went to restart and pull cord will not pull more then a few inches. How do I go about the fix?
If all the safety gear is working on the mower; Possibly sounds like you let it run low on oil and the engine is locked up.
Which would mean a new mower.
Sep 29, 2009 | Mtd Garden
Yard Machine won't start
Maybe the Spring is broken in the housing, that is assuming you are talking about a problem with the pull cord. Your question is kinda vaque. Submit more information !
Sep 13, 2009 | Mtd 22" Yard Machine Push Mower
Craftsman Walk behind lawnmower how to replace the starter pull string
Remove cowling to acces pull start assembly. Have new cord on hand. Remove old cord fragments. Wind rotor 4-5 revolutions to tension spring and hold while threading new cord into slot. Knot new cord and slowly let it wind back into assembly.
Jul 09, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
usually theres just a few bolts to take off on the top, and the whole rip cord assembly will pull right out, allowing you to install the new one.
Change Oil
All lawn mower engines have a drain plug for draining the oil. Look for a square nut on the side of the engine
Jun 12, 2009 | Mtd 22" Yard Machine Push Mower
Starter rope broke on yard machine
Take the top off. Remove broken rope. Rewind spring until tight, then unwind one turn. Insert and knot new rope.
Jun 07, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
1,104 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
