Question about Canon PC-940 Black and White Copier
How do I get rid of blurry streaks down center of copy? The glass is clean.
  • 1,219 Answers
Check the drum unit, if the drum is covered with streaks replace the crg.
Check the fixing unit.
Posted on Jun 14, 2010
I have an hp LaserJet 3015 PCL-6 all in one printer, copier & fax. When I use the copy function, there is a black streak running down the length of the copied paper. I tried replacing the toner...
Clean the thin glass strip that sits to the left of the flat bed glass.
That is the glass used when the ADF is being utilized.
There is dirt on it causing the black streak.
Oct 11, 2011 | HP LaserJet 3015 All-In-One Printer
When copying leaves a lighter streak down center of page
Turn off the printer
Open the Scanner lid, Clean the Glass with clean cloth for any minute dust particle.
Close the lid and turn on the printer
Try to Copy, IT should work.
Regards,
Ron
Feb 18, 2011 | HP Photosmart C3180 All-In-One InkJet...
Horizontal streak
Clean the scanner strip glass. This is the small strip of glass that is just to the left of the large main glass. This is the only cause for black line (s) when copying using the ADF(top feed). If prints or copies fine from the glass then it is this strip glass needing to be cleaned.
May 04, 2010 | Ricoh Aficio 450 Copier
Dark streak
clean the glass lining. It is situated on the left of the glass when you open the document feeder...clean it with a damp cloth
Nov 17, 2009 | Xerox DocuPrint N17 Laser Printer
Dark streaks/lines (3) down center of copies
I don't know what model you're using, which would be very helpful, however, if you lift the Document feeder section where the originals are fed, there should be a narrow piece of glass, which is only used when the Document feeder is used. This must be completely clean -1 spec creates a solid line.
Mar 11, 2009 | Sharp Office Equipment & Supplies
Black streaks on copies. Gestetner 1302 How do I get rid of them
Do the streaks appear when you use the contact glass or just when you use the Automatic feeder?
If both, then you need to replace either the (drum unit) or the fuser roller(s).
If it just happens through the auto feeder, then lift up the "feed-in section" (left side) and clean the narrow scanner glass.
Mar 11, 2009 | Gestetner DSc224 Copier
Faxing and or copying a black streak developes, answer??
Open up the document feeder by pulling up and clean the scanner glass
Jan 11, 2009 | Brother MFC-5840CN All-In-One InkJet...
Lexmark X6170
Received fax is unreadable or blurry
Please go through the checklist below to see if the suggested action(s) can resolve the issue.
* Make sure the copy function is working well.
* Print a Clean nozzle page from the Maintenance menu. If the printout has unexpected white or color horizontal streaks or missing portions, print the Clean nozzle page again. If you are still experiencing streaks or mission portions, you may need to replace your cartridge(s).
* The cartridges may need to be aligned.
* You may need to ask the sender to increase their fax quality.
Sent fax is unreadable or blurry.
1. If the receiving party indicates that the fax output is unreadable or blurry, you may want to try increasing the fax quality.
2. Check the scanner glass for excess amounts of smudges and/or fingerprints. If the scanner glass needs cleaning, moisten a clean, lint-free cloth and gently wipe the scanner glass. Make sure the scanner glass is dry before scanning the next document.
Feb 29, 2008 | Lexmark X6170 All-In-One InkJet Printer
Copies and outgoing fax quality
your machine most likely has toner spills in it.
if you send faxes face side down follow these instructions ;
1- take out toner
2- look for thin glass strip on bottom inside the machine
3-wipe clean
if you make copies side up then do the same except look for glass strip on the upper side of machine
Nov 27, 2007 | Brother IntelliFAX 4100 Laser Fax
Canon PC-940 Black and White Copier Logo
121 people viewed this question
old marine
old marine
